Hi all.
Does anyone know if there is a camera (or even the function within Domoticz) that will allow you to setup PTZ points? Then when an action (for example, door bell pushed) the camera is sent to that point/location and starts recording or takes shots for a period of time?
I have a cheap outdoor PTZ that is a bit basic and would like to upgrade it, but unsure what to go for.
Cheers,
Stuart
Sent from my SM-G925F using Tapatalk
Domoticz with PTZ cameras
stuiow
- Domoticz version: 3.6857
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
pepijn
Re: Domoticz with PTZ cameras
There is no native support for PTZ, it's also not easy to build since every Chinese factory has a sort of own standard. (Except if you use ONVIF but this isn't always implemented correctly)
I use the selector switch for this purpose and added the different preset to the switch, using a http command to set the camera to the preset.
stuiow
Probably easier to get multiple cheaper I cameras then.
- Egregius
- Domoticz version: v2024.7
Isn't a pi with camera and pan/tilt good for that?
