Hi, above 25.5 degree C the temperature reading of my Alecto WS3500 on domoticz (installed on raspberry pi) is multiplied by a factor of two to 51 degree. This looked repeatable last couple of days however.......... since today, may 8th 2016 12:15 the reading is around 41.3 degrees where the value of the Alecto weather station is 28.5 degrees.
Any idea?
Incorrect temperature reading above 25.5 degree. C Alecto WS3500
- proza
- Domoticz version: 4.11415
Re: Incorrect temperature reading above 25.5 degree. C Alecto WS3500
Mine WS3500 Alecto temperature is working correct, highest temp. seen today 27,7 Stable version on Raspberry Pi
If you see me collapse, pause my Garmin fenix 3
Same issue here, updated to 1002 firmware for 3500, which did not fix the issue (latest version from git under Ubuntu).
- Target OS: -
will be corrected in the next RFXtrx firmware version
RFX-433, RFX-433EMC, RFX-868
Hi everyone,
I have a alecto WS4500 and I came across this site against.
But the links that I found were unfortunately dead links.
Can anyone tell me how I can read the data from a ws4500 with a raspberry pi?
(I have found that the ws3500 and the ws4500 has use the same sensors?)
Thanks for the effort!
