Hikvision DS-7716NI-SP communication with Domoticz
Thomasdc
Post by Thomasdc »
Hi!
I have several camera's conected to a Hikvision DS-7716NI-SP..
This NVR has '4 outputs' ((relais) who can be triggered when movement detection, wirebreak,... )
I am no linux user and have little knowledge about linux.
but i think it should be possible when a 'relay' is trigger instead of conectin wires to it.. using a json link to comunicate with my domoticz?
is there someone who knows if/how this can be done? so.. when movement detected from a certain camera/or when the relay is triggered. --> send a json command to domoticz (the nvr and domoticz are in the same network afterall.. )
Bikey
Domoticz version: 2020.x
Re: Hikvision DS-7716NI-SP communication with Domoticz
Post by Bikey »
You could connect a 433Mhz wireless doorbell to the relais output. If the output closes the circuit the doorbell sends a signal that can be received by Domoticz.
Thomasdc
Post by Thomasdc »
Bikey wrote:You could connect a 433Mhz wireless doorbell to the relais output. If the output closes the circuit the doorbell sends a signal that can be received by Domoticz.
yeah i was about to do this with mysensors, but then i thougt.. its linux a linux device.., I can connect into the device (putty).. maybe its posible to just send a json command to domoticz when the relais is triggered...
