oregon sensors in Dz
433Mhz opensource Receiver & Transmitter.
jackslayter
Domoticz version: stable
Post by jackslayter »
Hi, i have a rflink, in debug log in IDE i see my oregon sensors but not in domoticz, why?
it's the same with my OWL180.
whereas my other devices like door contact or kaku work fine
thank you
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Stuntteam
Re: oregon sensors in Dz
Post by Stuntteam »
Sounds like a bug.. check your email..
jackslayter
my cheap receiver/transmitter are so bad on rpi2, so i will buy Aurel transceiver rtx mid 5v
jackslayter
I have a problem with OWL 180, the data are received but not in the good field and the value is divided by 10
Stuntteam
Post by Stuntteam »
I will look into this..
jackslayter
Hi, you could have fix it ?
thx
maxmizer
Post by maxmizer »
I have the same problem with Oregon UVN800
RFlink =0.0
RfXcom=2
dugolf
Domoticz version: 3.7450
Post by dugolf »
With Domoticz Version: 2.3397 and RfLink V1.1 r30 with the plugon 48 as below and the arduino simulator of an oregon Temp/Humidity ; it is ok the sensor is detected.
RfLink plugin_048.c:
The plugin is updated to remove the first 4 bits of the message which are the 4 bits of synchro
//##                    This Plugin is only for use with the RFLink software package                   ##
//##                                     Plugin-48 Oregon V1/2/3                                       ##
 * This protocol takes care of receiving Oregon Scientific outdoor sensors that use the V1, V2 and V3 protocol
 * models: THC238, THC268, THN132N, THWR288A, THRN122N, THN122N, AW129, AW131, THGR268, THGR122X,
 *         THGN122N, THGN123N, THGR122NX, THGR228N, THGR238, WTGR800, THGR918, THGRN228NX, THGN500,
 *         THGR810, RTGR328N, THGR328N, Huger BTHR918, BTHR918N, BTHR968, RGR126, RGR682, RGR918, PCR122
 *         THWR800, THR128, THR138, THC138, OWL CM119, cent-a-meter, OWL CM113, Electrisave, RGR928
 *         UVN128, UV138, UVN800, Huger-STR918, WGR918, WGR800, PCR800, WGTR800, RGR126, BTHG968
 * Author             : StuntTeam, Thibaut Girka
 * Support            : http://sourceforge.net/projects/rflink/
 * License            : This code is free for use in any open source project when this header is included.
 *                      Usage of any parts of this code in a commercial application is prohibited!
 * Changelog: v0.1 beta
 * Technical information:
 * Supports Oregon V1, V2 and V3 protocol messages
 * Core code from https://github.com/Cactusbone/ookDecoder/blob/master/ookDecoder.ino
 * Copyright (c) 2014 Charly Koza [email protected] Copyright (c) 2012 Olivier Lebrun [email protected]
 * Copyright (c) 2012 Dominique Pierre (zzdomi) Copyright (c) 2010 Jean-Claude Wippler [email protected]
 * Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation
 * files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,
 * modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the Software
 * is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
#define OSV3_PULSECOUNT_MIN 50  // 126
#define OSV3_PULSECOUNT_MAX 290 // make sure to check the max length in plugin 1 as well..!
#ifdef PLUGIN_048
 * Many devices use 160 bits, known exceptions:
 * 0xEA4c         136 bits  // TH132N
 * 0xEA7c         240 bits  // UV138
 * 0x5A5D / 1A99  176 bits  // THGR918 / WTGR800
 * 0x5A6D         192 bits  // BTHR918N
 * 0x8AEC         192 bits  // RTGR328N
 * 0x9AEC         208 bits  // RTGR328N
 * 0xDA78         144 bits  // UVN800
 * 0x2A19         184 bits  // RCR800
 * 0x2A1d         168 bits  // WGR918
class DecodeOOK {
protected:
	byte total_bits, bits, flip, state, pos, data[25];
	virtual char decode(word width) = 0;
public:
	enum { UNKNOWN, T0, T1, T2, T3, OK, DONE };
	DecodeOOK() { resetDecoder(); }
	bool nextPulse(word width) {
		if (state != DONE)
			switch (decode(width)) {
			case -1: resetDecoder(); break;
			case 1:  done(); break;
		return isDone();
	bool isDone() const { return state == DONE; }
	const byte* getData(byte& count) const {
		count = pos;
		return data;
	void resetDecoder() {
		total_bits = bits = pos = flip = 0;
		state = UNKNOWN;
	// add one bit to the packet data buffer
	virtual void gotBit(char value) {
		total_bits++;
		byte *ptr = data + pos;
		*ptr = (*ptr >> 1) | (value << 7);
		if (++bits >= 8) {
			bits = 0;
			if (++pos >= sizeof data) {
				resetDecoder();
				return;
		state = OK;
	// store a bit using Manchester encoding
	void manchester(char value) {
		flip ^= value; // manchester code, long pulse flips the bit
		gotBit(flip);
	// move bits to the front so that all the bits are aligned to the end
	void alignTail(byte max = 0) {
		// align bits
		if (bits != 0) {
			data[pos] >>= 8 - bits;
			for (byte i = 0; i < pos; ++i)
				data[i] = (data[i] >> bits) | (data[i + 1] << (8 - bits));
			bits = 0;
		// optionally shift bytes down if there are too many of 'em
		if (max > 0 && pos > max) {
			byte n = pos - max;
			pos = max;
				data[i] = data[i + n];
	void reverseBits() {
		for (byte i = 0; i < pos; ++i) {
			byte b = data[i];
			for (byte j = 0; j < 8; ++j) {
				data[i] = (data[i] << 1) | (b & 1);
				b >>= 1;
	void reverseNibbles() {
			data[i] = (data[i] << 4) | (data[i] >> 4);
	void done() {
		while (bits)
			gotBit(0); // padding
		state = DONE;
class OregonDecoderV1 : public DecodeOOK {
	public:
		OregonDecoderV1_org() {}
			virtual char decode(word width) {
			if (200 <= width && width < 1200) {
				byte w = width >= 700;
				switch (state) {
					case UNKNOWN:
						if (w == 0)
							++flip;
						else if (10 <= flip && flip <= 50) {
							flip = 1;
							manchester(1);
							return -1;
						break;
					case OK:
						if (w == 0)
							state = T0;
							manchester(1);
						break;
					case T0:
						if (w == 0)
							manchester(0);
							return -1;
						break;
				return 0;
			if (width >= 2500 && pos >= 9)
				return 1;
			return -1;
class OregonDecoderV2 : public DecodeOOK {
public:
	OregonDecoderV2() {}
		if (!(total_bits & 0x01))
			data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00);
		total_bits++;
		pos = total_bits >> 4;
		if (pos >= sizeof data) {
			resetDecoder();
			return;
		state = OK;
		//if (200 <= width && width < 1200) {
		//	byte w = width >= 675;
		if (150 <= width && width < 1200) {
			byte w = width >= 600;
			switch (state) {
			case UNKNOWN:
				if (w != 0) {
					// Long pulse
					++flip;
				else if (w == 0 && 24 <= flip) {
					// Short pulse, start bit
					flip = 0;
					state = T0;
				else {
					// Reset decoder
					return -1;
				break;
			case OK:
				if (w == 0) {
					// Short pulse
					state = T0;
				else {
					// Long pulse
					manchester(1);
				break;
			case T0:
				if (w == 0) {
					// Second short pulse
					manchester(0);
				else {
					// Reset decoder
					return -1;
				break;
		else if (width >= 2500 && pos >= 8) {
			return 1;
		else {
			return -1;
		return total_bits == 160 ? 1 : 0;
class OregonDecoderV3 : public DecodeOOK {
public:
	OregonDecoderV3() {}
		total_bits++;
		pos = total_bits >> 3;
			resetDecoder();
			return;
		state = OK;
			switch (state) {
			case UNKNOWN:
				if (w == 0)
					++flip;
				else if (32 <= flip) {
					flip = 1;
					manchester(1);
					return -1;
				break;
			case OK:
				if (w == 0)
					state = T0;
					manchester(1);
				break;
			case T0:
				if (w == 0)
					manchester(0);
					return -1;
				break;
		else {
			return -1;
		return  total_bits == 80 ? 1 : 0;
OregonDecoderV1 orscV1;
OregonDecoderV2 orscV2;
OregonDecoderV3 orscV3;
volatile word pulse;
byte osdata[13];
void reportSerial(class DecodeOOK& decoder) {
	byte pos;
	const byte* data = decoder.getData(pos);
        if (i < 13) osdata[i]=data[i];
	decoder.resetDecoder();
// calculate a packet checksum by performing a
byte checksum(byte type, int count, byte check) {
     byte calc=0;
     // type 1, add all nibbles, deduct 10
     if (type == 1) {
        for(byte i = 0; i<count;i++) {
           calc += (osdata[i]&0xF0) >> 4;
           calc += (osdata[i]&0xF);
        calc=calc-10;
     } else
     // type 2, add all nibbles up to count, add the 13th nibble , deduct 10
     if (type == 2) {
        calc += (osdata[6]&0xF);
        calc=calc-10;
     } else
     // type 3, add all nibbles up to count, subtract 10 only use the low 4 bits for the compare
     if (type == 3) {
        calc=calc-10;
        calc=(calc&0x0f);
     } else
     if (type == 4) {
        calc=calc-10;
     if (check == calc ) return 0;
     return 1;
boolean Plugin_048(byte function, char *string) {
      if ((RawSignal.Number < OSV3_PULSECOUNT_MIN) || (RawSignal.Number > OSV3_PULSECOUNT_MAX) ) return false;
      byte rc=0;
      byte found = 0;
      int temp = 0;
      byte hum = 0;
      int comfort = 0;
      int baro = 0;
      int forecast = 0;
      int uv = 0;
      int wdir = 0;
      int wspeed = 0;
      int awspeed = 0;
      int rain = 0;
      int raintot = 0;
      word p = pulse;
      for (int x = 1; x < RawSignal.Number; x++) {
      //for (int x = 0; x < RawSignal.Number; x++) {
          p = RawSignal.Pulses[x]*RawSignal.Multiply;
          if (p != 0) {
             if (orscV1.nextPulse(p)) {
                reportSerial(orscV1);
                found=1;
             if (orscV2.nextPulse(p)) {
                reportSerial(orscV2);
                found=2;
             if (orscV3.nextPulse(p)) {
                reportSerial(orscV3);
                found=3;
	  // Serial.print("found = ");
	  // Serial.println(found);
      if (found == 0)
		  return false;
	  // M.G. Remove 4 Sync bits (lower 4 bits of first byte)
	  if (found == 2) {
		for(byte x=0; x<13;x++) {
			osdata[x] = (osdata[x] >> 4);
			if (x < 12)
				osdata[x] += (osdata[x+1] & 0x0f) << 4;
      // Protocol and device info:
      // Serial.print("Oregon V");
      // Serial.print(found);
      // Serial.print(": ");
      // for(byte x=0; x<13;x++) {
      //    Serial.print( osdata[x],HEX );
      //    Serial.print((" "));
      // Serial.println();
      // Serial.print("Oregon ID=");
      unsigned int id=(osdata[0]<<8)+ (osdata[1]);
      rc=osdata[0];
      // Serial.println(id,HEX);
      // Process the various device types:
      // Oregon V1 packet structure
      // SL-109H, AcuRite 09955
      // TEMP + CRC
      // 8487101C
      // 84+87+10=11B > 1B+1 = 1C
      if (found==1) {       // OSV1
         int sum = osdata[0]+osdata[1]+osdata[2];  // max. value is 0x2FD
         sum= (sum &0xff) + (sum>>8);              // add overflow to low byte
         if (osdata[3] != (sum & 0xff) ) {
            //Serial.println("CRC Error");
            return false;
         //temp = ((osdata[2]>>4) * 100)  + ((osdata[1] & 0x0F) * 10) + ((osdata[1] >> 4));
         //if ((osdata[2] & 0x02) == 2) temp=temp | 0x8000;  // bit 1 set when temp is negative, set highest bit on temp valua
         temp = ((osdata[2] & 0x0F) * 100)  + ((osdata[1] >> 4) * 10) + ((osdata[1] & 0x0F));
         if ((osdata[2] & 0x20) == 0x20) temp=temp | 0x8000;  // bit 1 set when temp is negative, set highest bit on temp valua
        // Output
        Serial.print("20;");
        PrintHexByte(PKSequenceNumber++);
        Serial.print(F(";OregonV1;ID=00"));           // Label
        //sprintf(pbuffer, "ID=00%02x;", rc & 0xCF);
        PrintHexByte((rc)&0xcf);                      // rolling code + channel
        sprintf(pbuffer, ";TEMP=%04x;", temp);
        Serial.print( pbuffer );
        if (osdata[2] & 0x80) {
           Serial.print(F("BAT=LOW;"));
        } else {
           Serial.print(F("BAT=OK;"));
        Serial.println();
      // ea4c  Outside (Water) Temperature: THC238, THC268, THN132N, THWR288A, THRN122N, THN122N, AW129, AW131
      // TEMP + BAT + CRC
      // ca48  Pool (Water) Temperature: THWR800
      // 0a4d  Indoor Temperature: THR128, THR138, THC138
      // OSV2 EA4C20725C21D083 // THN132N
      // OSV2 EA4C101360193023 // THN132N
      // OSV2 EA4C40F85C21D0D4 // THN132N
      // OSV2 EA4C20809822D013
      //      0123456789012345
      //      0 1 2 3 4 5 6 7
      if(id == 0xea4c || id == 0xca48 || id == 0x0a4d) {
        byte sum=(osdata[7]&0x0f) <<4;
        sum=sum+(osdata[6]>>4);
        if ( checksum(2,6, sum) !=0) {  // checksum = all nibbles 0-11+13 results is nibbles 15 <<4 + 12
            return false;
        temp = ((osdata[5]>>4) * 100)  + ((osdata[5] & 0x0F) * 10) + ((osdata[4] >> 4));
        if ((osdata[6] & 0x0F) >= 8) temp=temp | 0x8000;
        // Output
        Serial.print(F(";Oregon Temp;ID="));           // Label
        //PrintHexByte(rc);
        PrintHexByte(osdata[3]);
        PrintHexByte(osdata[2]);
        //if ((osdata[3] & 0x0F) >= 4) {
        if ((osdata[4] & 0x0c) >= 4) {
        } else {
        Serial.println();
      } else
      // 1a2d  Indoor Temp/Hygro: THGN122N, THGN123N, THGR122NX, THGR228N, THGR238, THGR268, THGR122X
      // 1a3d  Outside Temp/Hygro: THGR918, THGRN228NX, THGN500
      // fa28  Indoor Temp/Hygro: THGR810
      // *aac  Outside Temp/Hygro: RTGR328N
      // ca2c  Outside Temp/Hygro: THGR328N
      // fab8  Outside Temp/Hygro: WTGR800
      // TEMP + HUM sensor + BAT + CRC
      // OSV2 AACC13783419008250AD[RTGR328N,...] Id:78 ,Channel:0 ,temp:19.30 ,hum:20 ,bat:10
      // OSV2 1A2D40C4512170463EE6[THGR228N,...] Id:C4 ,Channel:3 ,temp:21.50 ,hum:67 ,bat:90
      // OSV2 1A2D1072512080E73F2C[THGR228N,...] Id:72 ,Channel:1 ,temp:20.50 ,hum:78 ,bat:90
      // OSV2 1A2D103742197005378E // THGR228N
      // OSV3 FA28A428202290834B46 //
      // OSV3 FA2814A93022304443BE // THGR810
      // OSV2 1A2D1002 02060552A4C
      //      1A3D10D91C273083..
      //      1A3D10D90C284083..
      //      01234567890123456789
      //      0 1 2 3 4 5
      // F+A+2+8+1+4+A+9+3+0+2+2+3+0+4+4=4d-a=43
      if(id == 0xfa28 || id == 0x1a2d || id == 0x1a3d || (id&0xfff)==0xACC || id == 0xca2c || id == 0xfab8 ) {
        if ( checksum(1,8,osdata[8]) !=0) return false;   // checksum = all nibbles 0-15 results is nibbles 16.17
        hum = ((osdata[7] & 0x0F)*16)+ (osdata[6] >> 4);
        // Output
        Serial.print(F(";Oregon TempHygro;ID="));           // Label
        PrintHexByte(osdata[1]);
        sprintf(pbuffer, "HUM=%02x;", hum);
        if ((osdata[4] & 0x0F) >= 4) {
        } else {
        Serial.println();
      } else
      // 5a5d  Indoor Temp/Hygro/Baro: Huger - BTHR918
      // 5a6d  Indoor Temp/Hygro/Baro: BTHR918N, BTHR968. BTHG968
      // TEMP + HUM + BARO + FORECAST + BAT
      // NO CRC YET
      // 5A 6D 00 7A 10 23 30 83 86 31
      // 5+a+6+d+7+a+1+2+3+3+8+3=47 -a=3d  +8=4f +8+6=55
      // 5+a+6+d+7+a+1+2+3+3=3c-a=32
      // 5+a+6+d+7+a+1+2+3+3+0+8+3+8+6=55 -a =4b +3=4e !=1
      // 0  1  2  3  4  5  6  7  8  9
      if(id == 0x5a6d || id == 0x5a5d || id == 0x5d60) {
        hum = ((osdata[7] & 0x0F)*10)+ (osdata[6] >> 4);
        //0: normal, 4: comfortable, 8: dry, C: wet
        int tmp_comfort = osdata[7] >> 4;
        if (tmp_comfort == 0x00)
			comfort=0;
		else if (tmp_comfort == 0x04)
			comfort=1;
		else if (tmp_comfort == 0x08)
			comfort=2;
		else if (tmp_comfort == 0x0C)
			comfort=3;
        baro = (osdata[8] + 856);  // max value = 1111 / 0x457
        //2: cloudy, 3: rainy, 6: partly cloudy, C: sunny
        int tmp_forecast = osdata[9]>>4;
        if (tmp_forecast == 0x02)
			forecast = 3;
        else if (tmp_forecast == 0x03)
			forecast = 4;
        else if (tmp_forecast == 0x06)
			forecast = 2;
        else if (tmp_forecast == 0x0C)
			forecast = 1;
        // Output
        Serial.print(F(";Oregon BTHR;ID="));           // Label
        PrintHexByte(rc);
        sprintf(pbuffer, "HSTATUS=%d;", comfort);
        sprintf(pbuffer, "BARO=%04x;", baro);
        sprintf(pbuffer, "BFORECAST=%d;", forecast);
		//below is not correct, and for now discarded
        //if (((osdata[3] & 0x0F) & 0x04) != 0) {
        //   Serial.print("BAT=LOW;");
        //} else {
        //   Serial.print("BAT=OK;");
        Serial.println();
      } else
      // 2914  Rain Gauge:
      // 2d10  Rain Gauge:
      // 2a1d  Rain Gauge: RGR126, RGR682, RGR918, RGR928, PCR122
      // 2A1D0065502735102063
      // 2+A+1+D+0+0+6+5+5+0+2+7+3+5+1+0+2+0=3e-a=34 != 63
      // 2+A+1+D+0+0+6+5+5+0+2+7+3+5+1+0+2+0+6=44-a=3A
      if(id == 0x2a1d || id == 0x2d10 || id == 0x2914) { // Rain sensor
        //Checksum - add all nibbles from 0 to 8, subtract 9 and compare
        int cs = 0;
        for (byte i = 0; i < pos-2; ++i) { //all but last byte
            cs += data[i] >> 4;
            cs += data[i] & 0x0F;
        int csc = (data[8] >> 4) + ((data[9] & 0x0F)*16);
        cs -= 9;  //my version as A fails?
        Serial.print(csc);
        Serial.print(" vs ");
        Serial.println(cs);
        rain = ((osdata[5]>>4) * 100)  + ((osdata[5] & 0x0F) * 10) + (osdata[4] >> 4);
        raintot = ((osdata[7]  >> 4) * 10)  + (osdata[6]>>4);
        // Output
        Serial.print(F(";Oregon Rain;ID="));           // Label
        PrintHexByte(rc);
        sprintf(pbuffer, ";RAIN=%04x;", rain);
        sprintf(pbuffer, "RAINTOT=%04x;", raintot);
        } else {
        Serial.println();
      } else
      // 2a19  Rain Gauge: PCR800
      // RAIN + BAT + CRC
      // OSV3 2A19048E399393250010
      // 2+A+1+9+0+4+8+E+3+9+9+3+9+3+2+5=5b-A=51 => 10
      if(id == 0x2a19) { // Rain sensor
        int sum = (osdata[9] >> 4);
        if ( checksum(3,9,sum) !=0) { // checksum = all nibbles 0-17 result is nibble 18
            //Serial.print("CRC Error, ");
            return false;
        //Serial.print(" RainTotal=");
        //raintot = ((osdata[7]  >> 4) * 10)  + (osdata[6]>>4);
        //Serial.print(raintot);
        // Output
        Serial.print(F(";Oregon Rain2;ID="));           // Label
        PrintHexByte(rc);
        PrintHexByte(osdata[4]);
        sprintf(pbuffer,";RAIN=%04x;", rain);
        //sprintf(pbuffer, "RAINTOT=%04x;", raintot);
        //Serial.print( pbuffer );
        } else {
        Serial.println();
      } else
      // 1a89  Anemometer: WGR800
      // WIND DIR + SPEED + AV SPEED + CRC
      // OSV3 1A89048800C026400543
      // OSV3 1A89048800C00431103B
      // OSV3 1a89048848c00000003e W
      // OSV3 1a890488c0c00000003e E
      //      1A89042CB0C047000147
      // 1+A+8+9+0+4+8+8+0+0+C+0+0+4+3+1+1+0=45-a=3b
      if(id == 0x1a89) { // Wind sensor
        if ( checksum(1,9,osdata[9]) !=0) return false;
        wdir=((osdata[4] >> 4) & 0x0f);
        wspeed = (osdata[6] >> 4) * 10;
        wspeed = wspeed + (osdata[6] &0x0f) * 100;
        wspeed = wspeed + (osdata[5] &0x0f);
        awspeed = (osdata[8] >> 4) * 100;
        awspeed = awspeed + (osdata[7] &0x0f) * 10;
        awspeed = awspeed + (osdata[7] >> 4);
        // Output
        Serial.print(F(";Oregon Wind;ID="));           // Label
        PrintHexByte(rc);
        sprintf(pbuffer, ";WINDIR=%04d;", wdir);
        sprintf(pbuffer, "WINSP=%04x;", wspeed);
        sprintf(pbuffer, "AWINSP=%04x;", awspeed);
        } else {
        Serial.println();
      } else
      // 3a0d  Anemometer: Huger-STR918, WGR918
      // 1984  Anemometer:
      // 1994  Anemometer:
      // WIND DIR + SPEED + AV SPEED + BAT + CRC
      // 3A0D006F400800000031
      if(id == 0x3A0D || id == 0x1984 || id == 0x1994 ) {
        if ( checksum(1,9,osdata[9]) !=0) {
            return false;
        wdir = ((osdata[5]>>4) * 100)  + ((osdata[5] & 0x0F * 10) ) + (osdata[4] >> 4);
        wdir=wdir / 22.5;
        wspeed = ((osdata[7] & 0x0F) * 100)  + ((osdata[6]>>4) * 10)  + ((osdata[6] & 0x0F)) ;
        awspeed = ((osdata[8]>>4) * 100)  + ((osdata[8] & 0x0F) * 10)+((osdata[7] >>4)) ;
        // Output
        Serial.print(F(";Oregon Wind2;ID="));           // Label
        PrintHexByte(rc);
        } else {
        Serial.println();
	  } else
      // ea7c  UV Sensor: UVN128, UV138
      // UV + BAT
      // NO CRC YET
      if(id == 0xea7c) {
        uv=((osdata[5] & 0x0F) * 10)  + (osdata[4] >> 4);
        Serial.print(uv);
        // Output
        Serial.print(F(";Oregon UVN128/138;ID="));           // Label
        PrintHexByte(rc);
        sprintf(pbuffer, ";UV=%04x;", uv);
        } else {
        Serial.println();
      } else
      // da78  UV Sensor: UVN800
      // UV
      // NO CRC YET
      if( id == 0xda78) {
        uv=(osdata[6] & 0xf0) + (osdata[5] &0x0f) ;
        // Output
        Serial.print(F(";Oregon UVN800;ID="));               // Label
        PrintHexByte(rc);
        } else {
        Serial.println();
      } else
      // *aec  Date&Time: RTGR328N
      // 8A EC 13 FC 60 81 43 91 11 30 0 0 0 ;
      // 8+A+E+C+1+3+F+C+6+0+8+1+4+3+9+1=6B -A=61  != 30
      // 8+A+E+C+1+3+F+C+6+0+8+1+4+3+9=6a-A=60 0=0
      // NO CRC YET
      //20;06;Oregon Unknown;DEBUG=8A EC 13 FC 60 81 43 91 11 30 0 0 0 ;
      //20;20;Oregon Unknown;DEBUG=8A EC 13 FC 40 33 44 91 11 30 0 0 0 ;
      // 8AEA1378077214924242C16CBD  21:49 29/04/2014
      // 0 1 2 3 4 5 6 7 8 9 0 1 2
      // 8+A+E+A+1+3+7+8+0+7+7+2+1+4+9+2+4+2+4+2+C+1+6+C=88 !=   BD
      // Date & Time
      // eac0  Ampere meter: cent-a-meter, OWL CM113, Electrisave
      if(id == 0xeac0) {
        //Serial.println("UNKNOWN LAYOUT");
        // Output
        Serial.print(F(";Oregon Unknown;DEBUG="));                 // Label
        PrintHex8( osdata, 13);
        Serial.println(";");
      } else
      // 0x1a* / 0x2a* 0x3a** Power meter: OWL CM119
      // 0x628* Power meter: OWL CM180
      // OSV3 6284 3C 7801 D0
      // OSV3 6280 3C 2801 A0A8BA05 00 00 ?? ?? ??
      // 1a99  Anemometer: WGTR800
      // WIND + TEMP + HUM + CRC
      if(id == 0x1a99) { // Wind sensor
        // Output
      } else
      if( (id&0xf00)==0xA00 ) { // Any Oregon sensor with id xAxx
        // Output
      RawSignal.Repeats=true;                    // suppress repeats of the same RF packet
      RawSignal.Number=0;
      return true;
#endif // PLUGIN_048
Arduino oregon sensor simulator (Protocol V2.1):
433 TX_PIN 10
DHT11 sensor on pin 2
 * Oregon Scientific v2.1 Emitter with DHT11 sensor
   Exemple de trames:
   OSV2 EA4C106F7011D0D30300
   OSV2 EA4C106F6011C0A30600
   Bit 0 is sent first, then bit 1, 2, 3, 4, 5, 6, and then bit 7 of a byte
   The sample packet above is from a THGR122NX on channel 1 with rolling code  EC . It's returning a temperature of +27.3°C, and humidity 65%:
   1A 2D 10 EC 32 27 50 06 44 25
  - 0-3: Device ID. The ID for THGN132N sensors is  1A2D .
  - 4: Channel. This corresponds to the channel slider on the back of the sensor ( 1, 2, or 4 for channel 1, 2 or 3).
  - 5: Battery? All of my readings have 0 for this nibble. I'm half-expecting it to become non-zero on low battery.
  - 6-7: Rolling code. This is a unique identifier for the sensor. It resets when the battery is replaced.
  - 8: The tenths digit of the temperature.
  - 10: The tens digit of the temperature.
  - 11: The unit digit of the temperature.
  - 12: The unit digit of the humidity.
  - 13: The sign for the temperature. This nibble will be 0 for a +ve temp, and non-zero for -ve. During my testing with the sensor in the freezer, I've only seen this return 0 or 8.
  - 15: The tens digit of the humidity.
  |  Sensor Name      |  Code   | Type                   |
  |  Oregon-THR128    |         |                        |
  |  Oregon-THR138    | 0x0A4D  | Inside Temperature     |
  |  Oregon-THC138    |         |                        |
  | Oregon-THC238     |         |                        |
  | Oregon-THC268     |         |                        |
  | Oregon-THN132N    |         |                        |
  | Oregon-THWR288A   | 0xEA4C  | Outside/Water Temp     |
  | Oregon-THRN122N   |         |                        |
  | Oregon-THN122N    |         |                        |
  | Oregon-AW129      |         |                        |
  | Oregon-AW131      |         |                        |
  | Oregon-THWR800    | 0xCA48  | Water Temp             |
  | Oregon-THGN122N   |         |                        |
  | Oregon-THGN123N   |         |                        |
  | Oregon-THGR122NX  | 0x1A2D  | Inside Temp-Hygro      |
  | Oregon-THGR228N   |         |                        |
  | Oregon-THGR238    |         |                        |
  | Oregon-THGR268    |         |                        |
  | Oregon-THGR810    | 0xFA28  | Inside Temp-Hygro      |
  | Oregon-RTGR328N   | 0x*ACC  | Outside Temp-Hygro     |
  | Oregon-THGR328N   | 0xCA2C  | Outside Temp-Hygro     |
  | Oregon-WTGR800    | 0xFAB8  | Outside Temp-Hygro     |
  | Oregon-THGR918    |         |                        |
  | Oregon-THGRN228NX | 0x1A3D  | Outside Temp-Hygro     |
  | Oregon-THGN500    |         |                        |
  | Huger - BTHR918   | 0x5A5D  | Inside Temp-Hygro-Baro |
  | Oregon-BTHR918N   |         |                        |
  | Oregon-BTHR968    | 0x5A6D  | Inside Temp-Hygro-Baro |
  | Oregon-RGR126     |         |                        |
  | Oregon-RGR682     | 0x2A1D  | Rain Gauge             |
  | Oregon-RGR918     |         |                        |
  | Oregon-PCR800     | 0x2A19  | Rain Gauge             |
  | Oregon-WTGR800    | 0x1A99  | Anemometer             |
  | Oregon-WGR800     | 0x1A89  | Anemometer             |
  | Huger-STR918      |         |                        |
  | Oregon-WGR918     | 0x3A0D  | Anemometer             |
  | Oregon-UVN128     |         |                        |
  | Oregon-UV138      | 0xEA7C  | UV sensor              |
  | Oregon-UVN800     | 0xDA78  | UV sensor              |
  | Oregon-RTGR328N   | 0x*AEC  | Date & Time            |
  | cent-a-meter      |         |                        |
  | OWL CM113         | 0xEAC0  | Ampere meter           |
  | Electrisave       |         |                        |
  | OWL CM119         | 0x1A*                            |
  |                   | 0x2A*   | Power meter            |
  |                   | 0x3A**  |                        |
// defined THN132N Temp only
// undefined THGR228N Temp/Humidity
// #define THN132N
const byte TX_PIN = 10;
// Uncomment whatever type you're using!
#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
#define DHTPIN 2     // what pin we're connected to
#include "DHT.h"
// Initialize DHT sensor for normal 16mhz Arduino
DHT dht(DHTPIN, DHTTYPE);
// Outside/Water Temp
#define  Oregon_THN132N_ID   0xEA4C
// Inside Temp-Hygro
#define  Oregon_THGR228N_ID  0x1A2D
const unsigned long TIME = 512;
const unsigned long TWOTIME = TIME*2;
#define SEND_HIGH() digitalWrite(TX_PIN, HIGH)
#define SEND_LOW() digitalWrite(TX_PIN, LOW)
// Buffer for Oregon message
#ifdef THN132N
  byte OregonMessageBuffer[9];
#else
#endif
 * \brief    Send logical "0" over RF
 * \details  azero bit be represented by an off-to-on transition
 * \         of the RF signal at the middle of a clock period.
 * \         Remenber, the Oregon v2.1 protocol add an inverted bit first
inline void sendZero(void)
  SEND_HIGH();
  delayMicroseconds(TIME);
  SEND_LOW();
  delayMicroseconds(TWOTIME);
  SEND_HIGH();
 * \brief    Send logical "1" over RF
 * \details  a one bit be represented by an on-to-off transition
inline void sendOne(void)
   SEND_LOW();
   SEND_HIGH();
   SEND_LOW();
* Send a bits quarter (4 bits = MSB from 8 bits value) over RF
* @param data Source data to process and sent
 * \brief    Send a bits quarter (4 bits = MSB from 8 bits value) over RF
 * \param    data   Data to send
inline void sendQuarterMSB(const byte data)
  (bitRead(data, 4)) ? sendOne() : sendZero();
  (bitRead(data, 5)) ? sendOne() : sendZero();
  (bitRead(data, 6)) ? sendOne() : sendZero();
  (bitRead(data, 7)) ? sendOne() : sendZero();
 * \brief    Send a bits quarter (4 bits = LSB from 8 bits value) over RF
inline void sendQuarterLSB(const byte data)
  (bitRead(data, 0)) ? sendOne() : sendZero();
  (bitRead(data, 1)) ? sendOne() : sendZero();
  (bitRead(data, 2)) ? sendOne() : sendZero();
  (bitRead(data, 3)) ? sendOne() : sendZero();
 * \brief    Send a buffer over RF
 * \param    size   size of data to send
void sendData(byte *data, byte size)
  for(byte i = 0; i < size; ++i)
    sendQuarterLSB(data[i]);
    sendQuarterMSB(data[i]);
 * \brief    Send an Oregon message
 * \param    data   The Oregon message
void sendOregon(byte *data, byte size)
    sendPreamble();
    sendSync();
    sendData(data, size);
    sendPostamble();
 * \brief    Send preamble
 * \details  The preamble consists of 16 "1" bits
inline void sendPreamble(void)
  byte PREAMBLE[]={0xFF,0xFF};
  sendData(PREAMBLE, 2);
 * \brief    Send postamble
 * \details  The postamble consists of 8 "0" bits
inline void sendPostamble(void)
#ifdef THN132N
  sendQuarterLSB(0x00);
#else
  byte POSTAMBLE[]={0x00};
  sendData(POSTAMBLE, 1);
#endif
 * \brief    Send sync nibble
 * \details  The sync is 0xA. It is not use in this version since the sync nibble
 * \         is include in the Oregon message to send.
inline void sendSync(void)
  sendQuarterLSB(0xA);
 * \brief    Set the sensor type
 * \param    data       Oregon message
 * \param    type       Sensor type
inline void setType(byte *data, byte* type)
  data[0] = type[0];
  data[1] = type[1];
 * \brief    Set the sensor channel
 * \param    channel    Sensor channel (0x10, 0x20, 0x40)
inline void setChannel(byte *data, byte channel)
    data[2] = channel;
 * \brief    Set the sensor ID
 * \param    ID         Sensor unique ID
inline void setId(byte *data, byte ID)
  data[3] = ID;
 * \brief    Set the sensor battery level
 * \param    level      Battery level (0 = low, 1 = high)
void setBatteryLevel(byte *data, byte level)
  if(!level) data[4] = 0x0C;
  else data[4] = 0x00;
 * \brief    Set the sensor temperature
 * \param    temp       the temperature
void setTemperature(byte *data, float temp)
  // Set temperature sign
  if(temp < 0)
    data[6] = 0x08;
    temp *= -1;
    data[6] = 0x00;
  // Determine decimal and float part
  int tempInt = (int)temp;
  int td = (int)(tempInt / 10);
  int tf = (int)round((float)((float)tempInt/10 - (float)td) * 10);
  int tempFloat =  (int)round((float)(temp - (float)tempInt) * 10);
  // Set temperature decimal part
  data[5] = (td << 4);
  data[5] |= tf;
  // Set temperature float part
  data[4] |= (tempFloat << 4);
 * \brief    Set the sensor humidity
 * \param    hum        the humidity
void setHumidity(byte* data, byte hum)
    data[7] = (hum/10);
    data[6] |= (hum - data[7]*10) << 4;
 * \brief    Sum data for checksum
 * \param    count      number of bit to sum
int Sum(byte count, const byte* data)
  int s = 0;
    s += (data[i]&0xF0) >> 4;
    s += (data[i]&0xF);
  if(int(count) != count)
    s += (data[count]&0xF0) >> 4;
  return s;
 * \brief    Calculate checksum
void calculateAndSetChecksum(byte* data)
#ifdef THN132N
    int s = ((Sum(6, data) + (data[6]&0xF) - 0xa) & 0xff);
    data[6] |=  (s&0x0F) << 4;     data[7] =  (s&0xF0) >> 4;
#else
    data[8] = ((Sum(8, data) - 0xa) & 0xFF);
#endif
void setup()
  pinMode(TX_PIN, OUTPUT);
  Serial.begin(9600);
  Serial.println("\n[Oregon V2.1 encoder]");
  SEND_LOW();
#ifdef THN132N
  Serial.println("THN132N - temperature only");
  // Create the Oregon message for a temperature only sensor (TNHN132N)
  // byte ID[] = {0xEA,0x4C};
  byte ID[] = {Oregon_THN132N_ID >> 8,Oregon_THN132N_ID & 0xff};
#else
  Serial.println("THGR228N - temperature/humidity");
  // Create the Oregon message for a temperature/humidity sensor (THGR228N)
  // byte ID[] = {0x1A,0x2D};
  byte ID[] = {Oregon_THGR228N_ID >> 8,Oregon_THGR228N_ID & 0xff};
#endif
  setType(OregonMessageBuffer, ID);
  setChannel(OregonMessageBuffer, 0x20);
  setId(OregonMessageBuffer, 0xBB);
void loop()
  // Get Temperature, humidity and battery level from sensors
  // (ie: 1wire DS18B20 for température, ...)
  setBatteryLevel(OregonMessageBuffer, 1); // 0 : low, 1 : high
  // Read temperature as Celsius
  float t = dht.readTemperature();
  Serial.print("Temperature = ");
  Serial.print(t);
  Serial.println("C");
  setTemperature(OregonMessageBuffer, t);
#ifndef THN132N
  float h = dht.readHumidity() + 0.5;
  Serial.print("Humidity = ");
  Serial.print(h);
  Serial.println("%");
  // Set Humidity
  setHumidity(OregonMessageBuffer, (int)h);
#endif
  // Calculate the checksum
  calculateAndSetChecksum(OregonMessageBuffer);
  // Show the Oregon Message
  for (byte i = 0; i < sizeof(OregonMessageBuffer); ++i)   {
    Serial.print(OregonMessageBuffer[i] >> 4, HEX);
    Serial.print(OregonMessageBuffer[i] & 0x0F, HEX);
  Serial.println("");
  // Send the Message over RF
  sendOregon(OregonMessageBuffer, sizeof(OregonMessageBuffer));
  // Send a "pause"
  SEND_LOW();
  delayMicroseconds(TWOTIME*8);
  // Send a copie of the first message. The v2.1 protocol send the
  // message two time
  // Wait for 30 seconds before send a new message
  SEND_LOW();
  delay(30000);
Perhaps this can help you with real oregon sensor
Michel
dugolf
Post by dugolf »
I have downloaded the firmware RFLink_v1.1_r37 and it is working properly without any modification using the "Arduino oregon sensor simulator" above
Thanks to Stuntteam
dugolf
Post by dugolf »
Test with RFLink_v1.1_r37
1 - THN132N simulation
When i send EA4C106F30119003 the message is recognized by rflink as:
20;6E;Oregon Temp;ID=6F10;TEMP=0071;BAT=OK;
The ID is 6F10 where 10 is the channel
2 - THGR228N simulation
When i send 1A2D40C45021700639 the message is recognised by rflink as:
20;9D;Oregon TempHygro;ID=2DC4;TEMP=00d7;HUM=67;HSTATUS=0;BAT=OK;
The ID is 2DC4. It does not contain the channel number.
I thought as to THN132N , it would be equal to C440 where 40 is the channel number.
Where is my mistake ?
dugolf
Post by dugolf »
I think if there is a problem, it's in Plugin_048.c:
For THN132N (id == 0xea4c):
For THGR228N (id == 0x1a2d):
The begin of the buffer description is the same for THN132N & THGR228N.
osdata[0], osdata[1] = ea4c or 1a2d
osdata[2] = channel
osdata[3] = id
For THGR228N the code sould be the same:
am i right ?
