Hello
Is it planning the support for php in domoticz integrated web server?
Php_support in Domoticz server?
- Egregius
- Domoticz version: v2024.7
Re: Php_support in Domoticz server?
To run scripts or to host pages?
Either install php5 and/or apache2/nginx.
juankar
- Domoticz version: 4.
For running php pages.
But Domoticz always runs its own web server and set another serve on same ip and port....
The only way I can see is nginx. I'll investigate it.
- Egregius
You can easily do it by running on different port numbers.
juankar
Tanks, I've got it!!
I've used Apache proxy, I have this server installed so ...
I've used port 80, it canbe used any other 8090, 8100 ... not the same as domoticz
Thanks again
<VirtualHost *:80>
#Path to Domoticz www
DocumentRoot /opt/domoticz/www
#Don't proxy *.php, these files will pass trough apache server
ProxyRequests off
ProxyPassMatch ^/(.*\.php)$ !
#Redirect every call to domoticz www (running in port 8080)
ProxyPass / http://127.0.0.1:8080/
ProxyPassReverse / http://127.0.0.1:8080/
ProxyPreserveHost on
<Proxy *>
Order allow,deny
Allow from all
</Proxy>
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>Who is online
