Which water valve do you recommend that works with RFLink? I just want open and close a tap at certain times of the day.
Recommended water valve
Re: Recommended water valve
You could create a relay module from MySensors.org http://www.mysensors.org/build/relay attaching a NRF24L01 radio to the relay module http://www.mysensors.org/build/connect_radio and used Bloky in Domoticz to control the logic.
something like this valve - http://www.amazon.com/Adafruit-B8-OBDH- ... r+selinoid
or a normal sprinkler valve like this http://www.amazon.com/Orbit-57100-4-Inc ... r+selinoid.
- bbqkees
- Domoticz version: 4.1x
You should look at valves from Rain Bird. They are very solid.
- blackdog65
In my poly tunnel I use 4 of these
http://www.ebay.co.uk/itm/Thermal-Actua ... SwRLZT12yD sitting on 4 cheap TRV bodies on a home made manifold so that I can deliver water to sprinkler hoses.
I previously used the washing machine type solenoid valves which although "instant on/off" got VERY hot and not very reliable.
These new ones take 30 to 60 secs to open or close (not a problem for irrigation) but stay cool and cam be quickly replaced with a screw cap for manual override if necessary.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
oliviers
- Domoticz version: Stable
I use a couple of Rain Bird 100HVMM valves. They work under 24volts AC, so you also need a transformer/adapter. And any RFXCOM (or ZWAVE) wall plug to turn power on and off.
- 20160422_175817_resized (Copier).jpg (76.88 KiB) Viewed 4918 times
- 20160422_175514_resized (Copier).jpg (57.57 KiB) Viewed 4918 times
Paris area
Raspberry Pi 4 - RFXComm 433 - IrTrans - Zwave
jurgen
- Domoticz version: stable
Hi Oliviers,
I have a question about the schematic wire connection of the 24volts AC.
Do you have one transformator/adapter for more water valve's? in other words, can i use one transformator for 4 water valve's?
I would like to switch on and off the water valve's seperatly with one transformator.
Thank you for advice.
Kind Regards.
Jurgen
Kind Regards.
Jurgen
oliviers
Of course this is possible. But then you need to insert four "dry contact" relay modules between the transformer and your four valves, instead of just one wall switch module between the power outlet and the transformer. Modules such as Fibaro FIB_FGS-223, for example.
Oliviers
Oliviers
Paris area
jurgen
Hi Oliviers,
Thank you, i will try that.
I'm not sure which device i will use for swithing the power on/off, i can use zwave with zwave relay modules or using a wired relay bord like.
https://www.robbshop.nl/ethernet-module-8-relais
But thanks anyway!
But thanks anyway!
