I am building a solar power weather station :http://forum.mysensors.org/topic/841/so ... er-station
It works like a charm, for only 1 thing, the wind speed won't show up in domoticz as a device.
I use S_WIND/V_WIND and in the serial logs from the weather station i can see sending wind speed and in the mysensors serial gateway i see comming in wind speed.
In the hardware page in Domoticz i can see all the sensors of my weather station, including wind speed, but in the devices list all the sensors are present but not the wind speed (i blowto the wind speed sensor to generate some values, and i see them sending)
So why is the windspeed device not showing in my devices list ?
The Solar Weather station sketch:
#include <SPI.h>
#include <MySensor.h>
#include <dht.h>
#include <BH1750.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <MySigningAtsha204.h>
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
#define CHILD_ID_LIGHT 2
#define CHILD_ID_BARO 3
#define CHILD_ID_BTEMP 4
#define CHILD_ID_WINDSPEED 5
#define CHILD_ID_RAIN 6
#define MESSAGEWAIT 500
#define DIGITAL_INPUT_RAIN_SENSOR 3
#define HUMIDITY_SENSOR_DIGITAL_PIN 5
#define ENCODER_PIN 2
#define INTERRUPT DIGITAL_INPUT_RAIN_SENSOR-2
const int windSpeedPin = 2; // contact on pin 2 digital
int windSpeedPinCounter = 0; // impuls counter
int windSpeedPinStatus = 0; // actual impuls
int windSpeedPinStatusAlt = 0; // oude Impuls-Status
unsigned long windmeterStart;
unsigned long windmeterStartAlt = 0;
int windSpeed; // Variable voor Wind Speed
int beaufort = 0; // Variable Wind in Beaufort
const int windmeterTime = 10000;
//float knoten = 0.0;
//float wind = 0.0;
unsigned int knoten;
unsigned int wind;
boolean metric = false;
int altitude = 16; // meters above sealevel
float lastBmpTemp = -1;
float lastPressure = -1;
float lastHum = -1;
float lastTemp = -1;
double temp;
double hum;
int BATTERY_SENSE_PIN = A0;
int lastRainValue = -1;
int nRainVal;
boolean bIsRaining = false;
String strRaining = "NO";
int lastBatteryPcnt = 0;
int updateAll = 60;
int updateCount = 0;
uint16_t lastLux;
// unsigned long SLEEP_TIME = 60000;
unsigned long SLEEP_TIME = 600;
int batteryBasement = 800;
float batteryConstant = 100.0 / (1023 - batteryBasement);
MyTransportNRF24 radio; // NRFRF24L01 radio driver
MyHwATMega328 hw; // Select AtMega328 hardware profile
MySigningAtsha204 signer(true); // Select HW ATSHA signing backend
Adafruit_BMP085 bmp = Adafruit_BMP085();
BH1750 lightSensor;
dht DHT;
MySensor gw(radio, hw, signer);
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
MyMessage msgBtemp(CHILD_ID_BTEMP, V_TEMP);
MyMessage msgPressure(CHILD_ID_BARO, V_PRESSURE);
MyMessage msgWindSpeed(CHILD_ID_WINDSPEED, V_WIND);
MyMessage msgRain(CHILD_ID_RAIN, V_TRIPPED);
void setup()
analogReference(INTERNAL);
gw.begin(incomingMessage, 3, true);
//dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
bmp.begin();
gw.sendSketchInfo("Weather Sensor", "1.0");
gw.present(CHILD_ID_HUM, S_HUM, "WS Humidity");
gw.present(CHILD_ID_TEMP, S_TEMP, "WS Temperature");
gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "WS Lux");
gw.present(CHILD_ID_BARO, S_BARO, "WS Pressure");
gw.present(CHILD_ID_BTEMP, S_TEMP, "WS P Temperature");
gw.present(CHILD_ID_WINDSPEED, S_WIND, "WS Windspeed");
gw.present(CHILD_ID_RAIN, S_MOTION, "WS Rain");
pinMode(DIGITAL_INPUT_RAIN_SENSOR, INPUT);
lightSensor.begin();
metric = gw.getConfig().isMetric;
// Wind Meter https://github.com/chiemseesurfer/arduinoWeatherstation/blob/master/weatherstation/weatherstation.ino
float windmeter()
windmeterStart = millis(); // Actual start time measuringMessung
windmeterStartAlt = windmeterStart; // Save start time
windSpeedPinCounter = 0; // Set pulse counter to 0
windSpeedPinStatusAlt = HIGH; // Set puls status High
while ((windmeterStart - windmeterStartAlt) <= windmeterTime) // until 10000 ms (10 Seconds) ..
windSpeedPinStatus = digitalRead(windSpeedPin); // Read input pin 2
if (windSpeedPinStatus != windSpeedPinStatusAlt) // When the pin status changed
if (windSpeedPinStatus == HIGH) // When status - HIGH
windSpeedPinCounter++; // Counter + 1
windSpeedPinStatusAlt = windSpeedPinStatus; // Save status for next loop
windmeterStart = millis(); // Actual time
windSpeed = ((windSpeedPinCounter * 24) / 10) + 0.5; // WindSpeed - one Pulse ~ 2,4 km/h,
windSpeed = (windSpeed / (windmeterTime / 1000)); // Devided in measure time in seconds
Serial.print("wind Speed : ");
Serial.println(windSpeed);
knoten = windSpeed / 1.852; //knot's
return windSpeed;
void loop()
updateCount += 1;
if (updateCount == updateAll) {
lastTemp = -1;
lastHum = -1;
lastLux = -1;
lastBmpTemp = -1;
lastPressure = -1;
lastRainValue = -1;
lastBatteryPcnt = -1;
updateCount = 0;
delay(2000);
int chk = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
temp = DHT.temperature;
//Serial.print("Temperature DHT :");
//Serial.println(temp);
if (isnan(temp)) {
lastTemp = -1;
} else if (temp != lastTemp) {
lastTemp = temp;
if (!metric) {
temp = temp * 1.8 + 32.0;
gw.send(msgTemp.set(temp, 1));
hum = DHT.humidity;
if (isnan(hum)) {
lastHum = -1;
} else if (hum != lastHum) {
lastHum = hum;
gw.send(msgHum.set(hum, 1));
uint16_t lux = lightSensor.readLightLevel();
if (lux != lastLux) {
gw.send(msgLux.set(lux));
lastLux = lux;
float pressure = bmp.readSealevelPressure(altitude) * 0.01;
float bmptemp = bmp.readTemperature();
if (!metric) {
bmptemp = bmptemp * 1.8 + 32.0;
if (bmptemp != lastBmpTemp) {
gw.send(msgBtemp.set(bmptemp,1));
lastBmpTemp = bmptemp;
if (pressure != lastPressure) {
gw.send(msgPressure.set(pressure, 0));
lastPressure = pressure;
bIsRaining = !(digitalRead(DIGITAL_INPUT_RAIN_SENSOR));
Serial.print("Is Raining :");
Serial.println(bIsRaining);
if(bIsRaining){
strRaining = "YES";
else{
strRaining = "NO";
//Serial.print("Raining?: ");
//Serial.print(strRaining);
//Serial.print("\t Moisture Level: ");
//Serial.println(nRainVal);
//http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-rain-sensor-module-guide-and-tutorial/
gw.send(msgRain.set(bIsRaining, 1));
wind = windmeter();
Serial.print("Wind : ");
Serial.println(wind);
gw.send(msgWindSpeed.set(wind, 1));
int sensorValue = analogRead(BATTERY_SENSE_PIN);
int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
if (lastBatteryPcnt != batteryPcnt) {
gw.sendBatteryLevel(batteryPcnt);
lastBatteryPcnt = batteryPcnt;
gw.sleep(SLEEP_TIME);
void incomingMessage(const MyMessage & message) {
// We only expect one type of message from controller. But we better check anyway.
if (message.isAck()) {
Serial.println("This is an ack from gateway");
}Code: Select all
wind Speed : 8
Wind : 8
send: 3-3-0-0 s=5,c=1,t=8,pt=7,l=5,sg=0,st=ok:8.0
send: 3-3-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:40.4
send: 3-3-0-0 s=2,c=1,t=23,pt=3,l=2,sg=0,st=ok:114
send: 3-3-0-0 s=4,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.9
send: 3-3-0-0 s=3,c=1,t=4,pt=7,l=5,sg=0,st=ok:1008
Is Raining :0
send: 3-3-0-0 s=6,c=1,t=16,pt=7,l=5,sg=0,st=ok:0.0
wind Speed : 7
Wind : 7
send: 3-3-0-0 s=5,c=1,t=8,pt=7,l=5,sg=0,st=ok:7.0
send: 3-3-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:41.1
send: 3-3-0-0 s=2,c=1,t=23,pt=3,l=2,sg=0,st=ok:84
send: 3-3-0-0 s=4,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.8
Is Raining :0
wind Speed : 1
Wind : 1
0;0;3;0;9;read: 3-3-0 s=5,c=1,t=8,pt=7,l=5,sg=0:7.0
3;5;1;0;8;7.0
0;0;3;0;9;read: 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:41.1
3;0;1;0;1;41.1
0;0;3;0;9;read: 3-3-0 s=2,c=1,t=23,pt=3,l=2,sg=0:84
3;2;1;0;23;84
0;0;3;0;9;read: 3-3-0 s=4,c=1,t=0,pt=7,l=5,sg=0:21.8
3;4;1;0;0;21.8
0;0;3;0;9;read: 3-3-0 s=3,c=1,t=4,pt=7,l=5,sg=0:1008
3;3;1;0;4;1008
0;0;3;0;9;read: 3-3-0 s=6,c=1,t=16,pt=7,l=5,sg=0:0.0
3;6;1;0;16;0.0The hardware page in Domoticz :
Any help would be appriciated.
With regards
Peer
