Today, suddenly, domoticz web interface started to look ugly.
Please see screenshot. I mean those dick white backgrounds in section headers:
All was ok, and I made upgrade (as hundrets times earlier). And then it started to look like that.
What is really strange, I had this efect already before - but only on another pc when connecting to my domoticz from remote locations.
So at home I had normal, nice look and remote I had this ugly look. And now it started to look ugly even at home pc.
The same is on all domoticz screens, for example in settings.
And another thing - if I change theme in settings, there is completely no difference in the layout and colors - except of the background.
Is is correct?
Domoticz started to look ugly
Re: Domoticz started to look ugly
And I found the solution. It was because of browser cache.
I installed chrome extension: "clear cache" and after each theme selection I use this tool.
Now I see how different themes look like
- bbqkees
- Domoticz version: 4.1x
You do not need an extension.
Just type in: chrome://appcache-internals/ and delete the cache of the Domoticz site.
I have also tried to change theme but with no luck. Different browsers all show the same default theme regardless of what "flavour" I selected.
I have tried the browser cache trick but with no luck.. I out of ideas..
- Domoticz version: 3.4834
If u are using firefox, try pressing the clear browser cache button again and again until thefrezzie wrote:I have also tried to change theme but with no luck. Different browsers all show the same default theme regardless of what "flavour" I selected.
amount of used space for the cache is 0. Pressing the button 1 time will not clear the whole cache,
only a small amount of it.
Also delete the offline data for your domoticz-ip!
