MQTT
lebphi
MQTT
Post by lebphi »
hi,
i'm trying for a couple of days make working MQTT without success ... I don't understand how it works in domoticz.
1- how can i create une device MQTT (for exemple "outdoor temperature")
2- how can i update this device with a mqtt client (mqtt.fx for exemple) ? What is the exact syntax ?
I've read i've to use domoticz/in but i can't make working
regards
philippe
SweetPants
Re: MQTT
Post by SweetPants »
Did you follow the Wiki https://www.domoticz.com/wiki/MQTT
RidingTheFlow
Re: MQTT
Post by RidingTheFlow »
You create a "Dummy hardware", then it will allow you to create virtual devices of whatever type you want.
Then you can control them via MQTT messages.
lebphi
Re: MQTT
Post by lebphi »
Thanks it works with a virtual device. I've send as command { "idx" : 1, "nvalue" : 0, "svalue" : "30.6"}
