OWL CM119 - Log
SHadley1138
OWL CM119 - Log
Post by SHadley1138 »
Hi there
i have an OWL CM119, that appears to be reporting fine, but after an hour it seems to stop logging. when i look at the logs they are showing 0 other than the first hour. and the title bar of the device, also shows 0 Watts, however, the details of the device shows data being received and changing every few seconds. and if i put the kettle on, i see a power increase, as expected.
i think its more related to the fields in the DB rather than a hardware issue
any thoughts?
Westcott
Re: OWL CM119 - Log
Post by Westcott »
Which RFX receiver are you using?
