[MyDomoAtHome] Bêta version in nodeJS Topic is solved
epierre
Re: [MyDomoAtHome] Bêta version in nodeJS
Post by epierre »
@Justintime 0.0.50 should fix all, except water for I don't know why you dont't see the right values
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
epierre
Post by epierre »
0.0.52 does too the RGB dimmer
Justintime
Post by Justintime »
epierre wrote:@Justintime 0.0.49 should correct this one: Roller blinds switch
Thanks, But the Roller blind device is still not in the imperihome app visiable. I dont see the device anymore in ip:port/devices
Watermeter is working now.
epierre
Post by epierre »
what does /var/log/mydomoathome says about it ?
Justintime
epierre wrote:what does /var/log/mydomoathome says about it ?
I found This:
192.168.1.165 - - [02/Apr/2016:12:34:29 +0000] "GET /devices HTTP/1.0" 200 9671 "-" "-"
warn: Unknown type Blinds
epierre
Post by epierre »
ok got it, they have been moded out of Light* devices, pushing a correction to be tested v0.1.3
Justintime
Re: RE: Re: [MyDomoAtHome] Bêta version in nodeJS
epierre wrote:ok got it, they have been moded out of Light* devices, pushing a correction to be tested v0.1.3
OK thanks I will test. I did the update like this.
sudo apt-get update
sudo apt-get install MyDomoAtHome
Is that the best way?
epierre
Post by epierre »
if you are stuck in a previous version (as it appears if you installed before the repository), do:
sudo apt-get remove mydomoathome
sudo apt-get update
afterward just update & upgrade will be enough
Justintime
epierre wrote:if you are stuck in a previous version (as it appears if you installed before the repository), do:
sudo apt-get update
Hey man you are the greatest. Roller blinds are there now. Many thanks for your quick support.
Edit: was a bit to soon.... Sorry... But the stop button is not there. Image
epierre
Post by epierre »
too much p in stopable, pushing the correction now
Justintime
epierre wrote:too much p in stopable, pushing the correction now
epierre
Post by epierre »
also for blinds dimmers v0.1.7 just now
Centauri
Post by Centauri »
So i didn't notice this new version until now. But i am having troubles installing.
XXXXXX@XXXXXX:~$ sudo apt-get install MyDomoAtHome
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
  MyDomoAtHome
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/124 kB of archives.
After this operation, 373 kB of additional disk space will be used.
Selecting previously unselected package mydomoathome.
(Reading database ... 137852 files and directories currently installed.)
Preparing to unpack .../MyDomoAtHome_1.0.9_all.deb ...
/usr/bin/forever -> /usr/lib/node_modules/forever/bin/forever
[email protected] /usr/lib/node_modules/forever
├── [email protected]
├── [email protected] ([email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected], [email protected], [email protected], [email protected])
Unpacking mydomoathome (1.0.9) ...
Processing triggers for ureadahead (0.100.0-16) ...
Setting up mydomoathome (1.0.9) ...
npm ERR! Linux 3.13.0-83-generic
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--production"
npm ERR! node v4.4.2
npm ERR! npm  v2.2.0
npm ERR! path /home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall open
npm ERR! Error: EACCES: permission denied, open '/home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288'
npm ERR!     at Error (native)
npm ERR!  { [Error: EACCES: permission denied, open '/home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288']
npm ERR!   errno: -13,
npm ERR!   code: 'EACCES',
npm ERR!   syscall: 'open',
npm ERR!   path: '/home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288',
npm ERR!   parent: 'node-mydomoathome' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! Please include the following file with any support request:
npm ERR!     /usr/share/mydomoathome/app/npm-debug.log
dpkg: error processing package mydomoathome (--configure):
 subprocess installed post-installation script returned error exit status 243
Errors were encountered while processing:
 mydomoathome
E: Sub-process /usr/bin/dpkg returned an error code (1)
 npm version
{ npm: '2.2.0',
  ares: '1.10.1-DEV',
  http_parser: '2.5.2',
  icu: '56.1',
  modules: '46',
  node: '4.4.2',
  openssl: '1.0.2g',
  uv: '1.8.0',
  v8: '4.5.103.35',
  zlib: '1.2.8' }
node --version
v4.4.2
epierre
Post by epierre »
so I'll take the harder way... I'm pushing out a new version, do update before upgrade please
epierre
Post by epierre »
New version available
Justintime
Thanks, Where can i check on which version i am running?
epierre
Post by epierre »
you have it in the "no room"
Justintime
epierre wrote:you have it in the "no room"
Thanks, 0.1.26 running.
Can't live without Imperihome it's a great integration with Domoticz.
epierre
Post by epierre »
we're on 0.1.32 ;-)
Justintime
Hi Epierre,
Now the sun is shinning i saw that i am missing my sunscreen switch. Can you add this??
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Open",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 3,
"HardwareName" : "RFXCOM",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "00647E",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2016-05-08 12:52:29",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "Zonnescherm!",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RollerTrol, Hasta new",
"SwitchType" : "Blinds",
"SwitchTypeVal" : 3,
"Timers" : "false",
"Type" : "Blinds",
"TypeImg" : "blinds",
"Unit" : 2,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "1607",
"YOffset" : "376",
"idx" : "15"
EDIT:
Never mind i found it. I had to seacrh in a specific room tab. And not under "devices" as i thought "devices" would show all devices.
