[MyDomoAtHome] Bêta version in nodeJS Topic is solved
- epierre
Re: [MyDomoAtHome] Bêta version in nodeJS
@Justintime 0.0.50 should fix all, except water for I don't know why you dont't see the right values
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
- epierre
0.0.52 does too the RGB dimmer
Justintime
Thanks, But the Roller blind device is still not in the imperihome app visiable. I dont see the device anymore in ip:port/devicesepierre wrote:@Justintime 0.0.49 should correct this one: Roller blinds switch
Watermeter is working now.
- epierre
what does /var/log/mydomoathome says about it ?
Justintime
I found This:epierre wrote:what does /var/log/mydomoathome says about it ?
192.168.1.165 - - [02/Apr/2016:12:34:29 +0000] "GET /devices HTTP/1.0" 200 9671 "-" "-"
warn: Unknown type Blinds
- epierre
ok got it, they have been moded out of Light* devices, pushing a correction to be tested v0.1.3
Justintime
Re: RE: Re: [MyDomoAtHome] Bêta version in nodeJS
OK thanks I will test. I did the update like this.epierre wrote:ok got it, they have been moded out of Light* devices, pushing a correction to be tested v0.1.3
sudo apt-get update
sudo apt-get install MyDomoAtHome
Is that the best way?
- epierre
if you are stuck in a previous version (as it appears if you installed before the repository), do:
sudo apt-get remove mydomoathome
sudo apt-get update
afterward just update & upgrade will be enough
sudo apt-get update
Justintime
Hey man you are the greatest. Roller blinds are there now. Many thanks for your quick support.epierre wrote:if you are stuck in a previous version (as it appears if you installed before the repository), do:
sudo apt-get update
Edit: was a bit to soon.... Sorry... But the stop button is not there.
- epierre
too much p in stopable, pushing the correction now
Justintime
epierre wrote:too much p in stopable, pushing the correction now
- epierre
also for blinds dimmers v0.1.7 just now
So i didn't notice this new version until now. But i am having troubles installing.
XXXXXX@XXXXXX:~$ sudo apt-get install MyDomoAtHome
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following NEW packages will be installed:
MyDomoAtHome
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/124 kB of archives.
After this operation, 373 kB of additional disk space will be used.
Selecting previously unselected package mydomoathome.
(Reading database ... 137852 files and directories currently installed.)
Preparing to unpack .../MyDomoAtHome_1.0.9_all.deb ...
/usr/bin/forever -> /usr/lib/node_modules/forever/bin/forever
[email protected] /usr/lib/node_modules/forever
├── [email protected]
├── [email protected] ([email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected])
├── [email protected] ([email protected], [email protected], [email protected], [email protected])
└── [email protected] ([email protected], [email protected], [email protected], [email protected])
Unpacking mydomoathome (1.0.9) ...
Processing triggers for ureadahead (0.100.0-16) ...
Setting up mydomoathome (1.0.9) ...
npm ERR! Linux 3.13.0-83-generic
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--production"
npm ERR! node v4.4.2
npm ERR! npm v2.2.0
npm ERR! path /home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall open
npm ERR! Error: EACCES: permission denied, open '/home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288'
npm ERR! at Error (native)
npm ERR! { [Error: EACCES: permission denied, open '/home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288']
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'open',
npm ERR! path: '/home/XXXXX/.npm/forever/0.15.1/package/package.json.bc4dcf9d00bfbc732be7d2a381ec9288',
npm ERR! parent: 'node-mydomoathome' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! Please include the following file with any support request:
npm ERR! /usr/share/mydomoathome/app/npm-debug.log
dpkg: error processing package mydomoathome (--configure):
subprocess installed post-installation script returned error exit status 243
Errors were encountered while processing:
mydomoathome
E: Sub-process /usr/bin/dpkg returned an error code (1)
npm version
{ npm: '2.2.0',
ares: '1.10.1-DEV',
http_parser: '2.5.2',
icu: '56.1',
modules: '46',
node: '4.4.2',
openssl: '1.0.2g',
uv: '1.8.0',
v8: '4.5.103.35',
zlib: '1.2.8' }
node --version
v4.4.2- epierre
so I'll take the harder way... I'm pushing out a new version, do update before upgrade please
- epierre
New version available
Justintime
Thanks, Where can i check on which version i am running?
- epierre
you have it in the "no room"
Justintime
Thanks, 0.1.26 running.epierre wrote:you have it in the "no room"
Can't live without Imperihome it's a great integration with Domoticz.
- epierre
we're on 0.1.32
Justintime
Hi Epierre,
Now the sun is shinning i saw that i am missing my sunscreen switch. Can you add this??
Never mind i found it. I had to seacrh in a specific room tab. And not under "devices" as i thought "devices" would show all devices.
- Spoiler: show
