Powernode not reporting usage after x minutes
Testpilotdk
Post by Testpilotdk »
Hi Everybody,
Information about the system.
- Raspberry PI, with the newest beta installed (I have tried with the stable one as weel)
- AEotec Z-Stick 2 (USB device)
- Green wave powernodes (1 and 6 plug)
I have added the devices correctly to Domoticz and I'm able to see the different devices they have maked, I can turn on/off switches and see the first measurement in w, but after 2-3 minutes I stops reporting the usage on the plugs. The system sees them as working fine and I'm still able to turn them on/off.
If I then go into the OpenZWave Control, mark the different devices and under the current Values push the refresh button, they are updated with new Values, all over in Domoticz.
I have had a look in the log file for the system, this log is telling that I get some timeouts from the nodes.
Log file added further down.
So my real question is, how should this be treathed the rigth way, Is there a setting in Domoticz I have forgotten or should this be solved with a script calling this "refresh" every 2 minutes.
2016-03-29 20:09:13.218 OpenZWave: Received timeout notification from HomeID: 25483268, NodeID: 2 (0x02)
2016-03-29 20:09:13.482 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.484 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.516 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.518 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.549 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.551 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.582 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.584 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.616 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.618 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.656 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.658 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.689 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.695 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.722 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.725 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.755 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.757 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.789 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.791 (Aeotec) Usage (Power Meter)
2016-03-29 20:09:13.897 (Aeotec) Usage (Unknown)
2016-03-29 20:09:13.898 (Aeotec) Usage (Power Meter)
2016-03-29 20:23:52.778 OpenZWave: Received timeout notification from HomeID: 25483268, NodeID: 2 (0x02)
2016-03-29 21:27:22.600 OpenZWave: Received timeout notification from HomeID: 25483268, NodeID: 2 (0x02)
2016-03-29 22:33:23.979 OpenZWave: Received timeout notification from HomeID: 25483268, NodeID: 2 (0x02)
2016-03-29 22:53:37.150 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH BINARY, Label: Switch, Instance: 35
2016-03-29 22:53:37.151 (Aeotec) Light/Switch (Switch)
2016-03-29 22:53:37.170 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Unknown, Instance: 35
2016-03-29 22:53:37.170 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SWITCH BINARY, Label: Switch, Instance: 127
2016-03-29 22:53:37.171 (Aeotec) Light/Switch (Switch)
2016-03-29 22:53:37.176 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: METER, Label: Unknown, Instance: 127
2016-03-30 01:32:53.720 OpenZWave: Received timeout notification from HomeID: 25483268, NodeID: 2 (0x02)
2016-03-30 02:51:03.859 OpenZWave: Received timeout notification from HomeID: 25483268, NodeID: 2 (0x02)
2016-03-30 03:34:32.551 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.747 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.749 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.750 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.751 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.752 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.755 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.756 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.758 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.759 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.761 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.762 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.764 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.765 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.787 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.788 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.818 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.820 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.851 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.853 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.884 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.886 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.914 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.915 (Aeotec) Usage (Power Meter)
2016-03-30 03:34:32.943 (Aeotec) Usage (Unknown)
2016-03-30 03:34:32.944 (Aeotec) Usage (Power Meter)
Users browsing this forum: jvdz and 1 guest
