Easy event doesn't work - help
lukcinek
Post by lukcinek »
Hello
I'm trying to make some events in Domoticz but with no success:(
In attachment I put two examples of event that switch light on when motion is on.
One works but when I add time event it doesn't and I don't know why?
I also try to switch on my two lights named (włącznik and światło_przedpokój)when my motion sensor is on - between 10 and 12 o'clock and when may LUX sensor from Fibaro motion sensor is lover than - 50.
Help please
Czujnik ruchu - Motion sensor
Czujnik natężenia światła - LUX sensor
Sorry for my English
Best regards
lukcinek
Re: Easy event doesn't work - help
Post by lukcinek »
Anybody?
woody4165
Post by woody4165 »
You may try replacing the Czujnik ruchu (Motion sensor) with a dummy switch and check if it's working.
In case it's working, maybe the motion sensor does not return On or Off, but other values.
Have you checked launching from browser http://192.168.x.x:8080/json.htm?type=devices&rid=YY where YY is the idx of the motion sensor, trying with both states and check which value return.
lukcinek
Post by lukcinek »
woody4165 wrote:You may try replacing the Czujnik ruchu (Motion sensor) with a dummy switch and check if it's working.
Thank You for answer but...
From 3 examples i wrote, one is working well. There also is motion sensor = ON and script is working. I was thinking there is problem in other place of this script but I don't know where.
I checked (http://192.168.x.x:8080/json.htm?type=devices&rid=YY ) and my states are ON and OFF
Any idea?
woody4165
Post by woody4165 »
How did you put nested If in Blockly?
I was not able, don't know if this a browser issue (Chrome).
In any case, I suggest to go with Lua script, more indicated for "complicated" script...
lukcinek
Post by lukcinek »
woody4165 wrote:How did you put nested If in Blockly?
I don't use chrome. In chrome I had problems with all scripts (nothing worked). I'm using IE.
I solved my problem...I send photo of my new script (now everything works great)
Best regards
