Pushnotification when dishwasher/washing machine is ready?
- nayr
- Domoticz version: github
Re: Pushnotification when dishwasher/washing machine is read
happy to report that my Washing Machine, Clothes Dryer and Dish Washer are all using this script with great success..
The Dish Washer has a 30min timeout and a consumption_lower of 0.1w, this way it dont ask me to open it and I get blasted in the face with steam.. it goes right to 0w when its done, no idling around at the end.
Dryer since it is gas is very steady and dont idle about at all waiting for stuff to drain, used the same values I did for the washing machine and it's been fine.
I put these appliances in the $HiddenDevices room, the on/off switch are useless in a day to day need.. but I do want them available for scripts, I have a flood sensor in the basement shoved down an emergency drain, if something leaks or my sewer pipe clogs (it happens) it will trigger the washers to shutdown, so they dont contribute to the flooding... I am thinking of making a virtual override switch to enable during spring lightning storms, disconnect all non-critical equipment for say 12h.. just for extra safety, but then perhaps im trying to hard to find a use for the on/off switch huh?
Wife Approval Factor is very high, if only because I am more likely to getup and change a load out now that I know its in there and ready.
- Domoticz version: 2024.2
Thanks for the scripts. Working great for my washing machine after some script modifications.
My clothes dryer have some issues and sometimes it's stopping before the dry program is finished. So I wanted to know how long the dryer been running before it stopped.
Created a simple function that gives me e.g. 1 hour and 5 minutes in notifications. This might be useful for others.
function formatSeconds(seconds)
local hours = math.floor(seconds / 3600)
local seconds = seconds % 3600
local minutes = math.floor(seconds / 60)
local andTxt = ' and '
if hours == 1 then hoursTxt = ' hour' else hoursTxt = ' hours' end
if minutes == 1 then minutesTxt = ' minute' else minutesTxt = ' minutes' end
if hours == 0 then hoursTxt = '' hours = '' andTxt = '' end
if minutes == 0 then minutesTxt = '' minutes = '' andTxt = '' end
return hours .. hoursTxt .. andTxt .. minutes .. minutesTxt
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
print(formatSeconds(7304)) --Result: 2 hours and 1 minute
--Send notification example
commandArray['SendNotification']='Dryer#Dryer has stopped after ' .. formatSeconds(timedifference(uservariables_lastupdate['YOUR_USERVARIABLE'])) .. '#0'
- MaffeMuis
- Domoticz version: 3.9483
Re: Pushnotification when dishwasher/washing machine is ready?
Thank you for this script! Works great for my washing machine!
Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
- Plaagje
- Domoticz version: Latest
Kjakan wrote:Thanks for the scripts. Working great for my washing machine after some script modifications.
function formatSeconds(seconds) local hours = math.floor(seconds / 3600) local seconds = seconds % 3600 local minutes = math.floor(seconds / 60) local andTxt = ' and ' if hours == 1 then hoursTxt = ' hour' else hoursTxt = ' hours' end if minutes == 1 then minutesTxt = ' minute' else minutesTxt = ' minutes' end if hours == 0 then hoursTxt = '' hours = '' andTxt = '' end if minutes == 0 then minutesTxt = '' minutes = '' andTxt = '' end return hours .. hoursTxt .. andTxt .. minutes .. minutesTxt end function timedifference(s) year = string.sub(s, 1, 4) month = string.sub(s, 6, 7) day = string.sub(s, 9, 10) hour = string.sub(s, 12, 13) minutes = string.sub(s, 15, 16) seconds = string.sub(s, 18, 19) t1 = os.time() t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds} difference = os.difftime (t1, t2) return difference end print(formatSeconds(7304)) --Result: 2 hours and 1 minute --Send notification example commandArray['SendNotification']='Dryer#Dryer has stopped after ' .. formatSeconds(timedifference(uservariables_lastupdate['YOUR_USERVARIABLE'])) .. '#0'
this is a great addition to my script! thanx!
This is probably a silly question, but how do you configure where the messages in the script (such as 'Washing Machine#The load in the washing machine has finsihed, please move it to the dryer' go? I
Ah never mind, thats obviously just the default config from Domoticz...
- Domoticz version: 2.4538
sure the idle time is in minutes?, my log indicates it is much faster (seconds?):nayr wrote:modified your script a bit @ThinkPad to fix a lil bug,
copied the counter setup line from the first if statment, and added it to the second as an elseif condition:my full script: http://pastebin.com/w9aWiu3BCode: Select all
if (washer_usage < consumption_lower) and uservariables[washer_status_uservar] == 1 then --Washing machine is not using a lot of energy, subtract the counter commandArray['Variable:' .. washer_counter_uservar]=tostring(math.max(tonumber(uservariables[washer_counter_uservar]) - 1, 0)) print('Current power usage (' ..washer_usage.. 'W) is below lower boundary (' ..consumption_lower.. 'W), washer is idle or almost ready') print('Subtracting counter with 1, new value: ' ..uservariables[washer_counter_uservar].. ' minutes') elseif ((uservariables[washer_counter_uservar] ~= idle_minutes) and uservariables[washer_status_uservar] == 1) then commandArray['Variable:' .. washer_counter_uservar]=tostring(idle_minutes) end
this way the counter resets if its not idle for consecutive mins.. Watching a load wash now and I noticed wattage dropped real low but the counter did not reset after it went back up before timeout. My Washer gives a reminder tone @ 5mins and the notification came in within seconds of that going off.
2016-10-03 22:33:16.981 LUA: Subtracting counter, old value: 6 minutes
2016-10-03 22:33:16.981 EventSystem: Script event triggered: Vaskemaskin LUA
2016-10-03 22:33:26.625 LUA: Current power usage (0W) is below lower boundary (10W), washer is idle or almost ready
2016-10-03 22:33:26.625 LUA: Subtracting counter, old value: 5 minutes
2016-10-03 22:33:26.626 EventSystem: Script event triggered: Vaskemaskin LUA
2016-10-03 22:33:27.801 LUA: Current power usage (0W) is below lower boundary (10W), washer is idle or almost ready
2016-10-03 22:33:27.801 LUA: Subtracting counter, old value: 4 minutes
2016-10-03 22:33:27.801 EventSystem: Script event triggered: Vaskemaskin LUA
2016-10-03 22:33:30.062 LUA: Current power usage (0W) is below lower boundary (10W), washer is idle or almost ready
2016-10-03 22:33:30.062 LUA: Subtracting counter, old value: 3 minutes
2016-10-03 22:33:30.062 EventSystem: Script event triggered: Vaskemaskin LUA
2016-10-03 22:33:30.066 LUA: Current power usage (0W) is below lower boundary (10W), washer is idle or almost ready
2016-10-03 22:33:30.066 LUA: Subtracting counter, old value: 2 minutes
2016-10-03 22:33:30.066 EventSystem: Script event triggered: Vaskemaskin LUA
2016-10-03 22:33:30.068 LUA: Current power usage (0W) is below lower boundary (10W), washer is idle or almost ready
2016-10-03 22:33:30.068 LUA: Subtracting counter, old value: 1 minutes
2016-10-03 22:33:30.068 EventSystem: Script event triggered: Vaskemaskin LUA
2016-10-03 22:33:37.806 LUA: Current power usage (0W) is below lower boundary (10W), washer is idle or almost ready
2016-10-03 22:33:37.806 LUA: Subtracting counter, old value: 0 minutes
did a test.
looks like tha value "1000" equals 1h (or 60m)
local idle_minutes = 1000
Hi, as long as you make sure the script is defined as "time" script it really runs once a minute. If it is defined as "device" script it triggers for every device change which I guess could explain the above ( = about 1000 device changes in an hour). But yeah, once it is defined as time script, it'll work as intended and run only once a minute...Evelen wrote:did a test.
looks like tha value "1000" equals 1h (or 60m)Code: Select all
I have problem that the script runs to often and not every minute.
How do i define a script as a "time script"?
Nautilus wrote:Hi, as long as you make sure the script is defined as "time" script it really runs once a minute. If it is defined as "device" script it triggers for every device change which I guess could explain the above ( = about 1000 device changes in an hour). But yeah, once it is defined as time script, it'll work as intended and run only once a minute...Evelen wrote:did a test.
This is the script I'm using for my washing machine (based on power usage in watts):
-- Change Watt Device value to number and remove the word Watt
wattdevice = otherdevices_svalues['Washing Machine / Dryer Watts']
function stripchars(str, chrs)
local s = str:gsub("["..chrs.."]", '')
return s end
wattvalue = stripchars( wattdevice, " Watt" )
if (uservariables["WashingMachineState"] == 'notinuse' and tonumber(wattvalue) >= 10 ) then
commandArray['Variable:WashingMachineState'] = 'inuse'
if (uservariables["WashingMachineState"] == 'inuse' and tonumber(wattvalue) <= 1 ) then
commandArray['Variable:WashingMachineState'] = 'notinuse'
os.execute ('/var/www/tts/speak.sh "Kitchen" "The washing machine has finished."')
commandArray['SendNotification']='Notification#The washing machine has finished.'
If you have the script as text file in the lua directory, the naming needs to be script_time_XXX.lua. If you have it in the database (= are using the web interface for managing events) under the "Event name" section (top right) there's a dropdown selector with default value "All" that you need to change to "Time" and save the script.amblyo wrote: How do i define a script as a "time script"?
I missed that obvious dropdown in the webinterface.
Hope that it solves my problem.
i dont get it,
tried several scripts.
in the log i see (like every second)
How can i fix this?
it is this script:2017-04-12 22:57:47.654 Error: EventSystem: in script_time_wasmachine: [string "--script_time_washingmachine.lua ..."]:18: attempt to compare number with nil
--Change the values below to reflect to your own setup
local washer_status_uservar = 'washingmachine_status'
local energy_consumption = 'verbruik wasmachine' --Name of Z-Wave plug that contains actual consumption of washingmachine (in Watts)
local washer_counter_uservar = 'washingmachine_counter' --Name of the uservariable that will contain the counter that is needed
local idle_minutes = 5 --The amount of minutes the consumption has to stay below the 'consumption_lower' value
local consumption_upper = 20 --If usage is higher than this value (Watts), the washingmachine has started
local consumption_lower = 4.3 --If usage is lower than this value (Watts), the washingmachine is idle for a moment/done washing
-- sWatt, sTotalkWh = otherdevices_svalues['Clothes Washer Power Usage']:match("([^;]+);([^;]+)")
-- washer_usage = tonumber(sWatt)
washer_usage = tonumber(otherdevices_svalues[energy_consumption])
--Virtual switch is off, but consumption is higher than configured level, so washing has started
if (washer_usage > consumption_upper) and uservariables[washer_status_uservar] == 0 then
commandArray['Variable:' .. washer_status_uservar]='1'
print('Current power usage (' ..washer_usage.. 'W) is above upper boundary (' ..consumption_upper.. 'W), so washing has started!')
--Washing machine is not using a lot of energy, check the counter
print('Subtracting counter, old value: ' ..uservariables[washer_counter_uservar].. ' minutes')
print('Resetting Washing Machine Timer')
--Washingmachine is done
if ((uservariables[washer_status_uservar] == 1) and uservariables[washer_counter_uservar] == 0) then
print('Washingmachine is DONE')
print('Current power usage washingmachine ' ..washer_usage.. 'W')
print('Washingmachine is done, please go empty it!')
commandArray['SendNotification']='Cycle Ended: Washing Machine#The load in the washing machine has finsihed, please move it to the dryer!#0'
commandArray['Variable:' .. washer_status_uservar]='0'
If you have created the script via the event management in the web UI make sure the type is set as "Time" and not "All" or "Device". If you have stored it in the file system make sure the name starts with script_time_
Then Domoticz knows it's a time script and runs it only once a minute.
Thanks all for perfecting this script!
Just received my TP-Link HS110, and it got just notified of my first finished washing routine!
The notification comes around 10 minutes after actually finishing, my washing machine still does 'stuff' costing energy.
It also has anti-crease security that once in a while spins the drum. Maybe disabling this helps.
- Domoticz version: 3.5877
Just a wild idea and also perhaps ofThread .
Main thread is how to determine when a machine is done and then give a notification.
I want to focus on the later part since the detection phase is working . but instead of having a push notification like Pushover that i use, i would like to have a TTS message in my Sonos telling me that the "Laundry is done" Anyone having thoughts about how to do this ?
Besides Domoticz i also use HASS and their is a Sonos TTS interface that i thought might be usefull.
What would we do with all our time if we didnt have HomeAutomation
ask your wife:-)SiggeStardust wrote: What would we do with all our time if we didnt have HomeAutomation
it is created as time in the web ui.Nautilus wrote:If you have created the script via the event management in the web UI make sure the type is set as "Time" and not "All" or "Device". If you have stored it in the file system make sure the name starts with script_time_
When i reset the timer manually, it eventually will send my a notification when it returned to "5".
But when i start using the washingmachine, it does not reset.
