KNX interface
multinet
KNX interface
Hello
I've a heater/cooler using a AIRZONE (http://www.airzone.es) to set temperature n each room
It is possible to add a KNX gateway to my AIRZONE system (http://www.airzonefrance.fr/knx.php) in order to control it by a third party system.
I would like to know if it is possible to add a KNX hardware to my raspberry in order to control my temperature via domoticz.
Any help welcome
Multinet
Any help welcome
Multinet
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
6 sondes DS18B20
Skippiemanz
- Domoticz version: 4.10233
Re: KNX interface
I would be interested in this also...
Verstuurd vanaf mijn SM-G925F met Tapatalk
multinet
Re: KNX interface
Hello
I found a solution without Knx and just a relay board
Just making some tests before describing it
Are you still interested ?
6 sondes DS18B20
6 sondes DS18B20
v40jlt4
- Domoticz version: 2021.1
Re: KNX interface
If not, then I am!
I just bought a house that turns out to be loaded with hager knx-rf switches which I'd love to control via domoticz.
But trying to search KNX is already near impossible
So sharing any KNX-RF related knowledge would be welcome.
Skippiemanz
Re: KNX interface
No trying to be negative about domoticz but why not use the KNX(RF)? add a new IP Gateway like xxter or Pairott and your off to go! I hope ou got the KNX Project file with the purchase of the house..v40jlt4 wrote: Tuesday 24 April 2018 23:20If not, then I am!
v40jlt4
Re: KNX interface
Thanks for the heads up. In my current house I use z-wave stuff & domoticz. In the new house there are also multiple somfy blinds for which I bought a RFXtrx433E. I was hoping to make it all (including the KNX stuff) come together into domoticz.Skippiemanz wrote: Wednesday 25 April 2018 20:46 .....
But I'll look into all options.
And unfortunately, but no, no project files or any info on the KNX install
Thanks again
PS. some related stuff found here:
http://selfbus.myxwiki.org/xwiki/bin/vi ... FT12_Raspi
http://www.knx-forum.be/viewtopic.php?f ... 8&start=10
https://michlstechblog.info/blog/raspbe ... with-knxd/
Skippiemanz
Re: KNX interface
Perhaps there is a usb stick somewhere with the project file in the utility closet?? Without it it's gonna be a struggle to figure everything out.
I have some installs where xxter send out a json command to Domoticz.
Otherwise a relay soldered to the somfy remote and controlled by knx is also an option.
v40jlt4
Re: KNX interface
Found it, unfortunately it's a 16MB SmartMedia memory card that fits a hager TX100 programmer.Skippiemanz wrote: Thursday 10 May 2018 17:19 Perhaps there is a usb stick somewhere with the project file in the utility closet?? ...
Luckily, my friends from aliexpress have a card-reader that also reads SM for just €8.51. I'll be back in a few weeks.
Furthermore, I'm going to search for an (affordable) KNX-USB interface and try to go from there. E.g. hook up a PC/rPi
Skippiemanz
Re: KNX interface
Nice!
Ive got a spare ets 5 lite license if you're interested.
And a weinzerl usb gateway. Even if you like the xxter gateway i can get you a good deal on that.
v40jlt4
Re: KNX interface
Thx,
About the Weinzierl, which one is it?
Skippiemanz
v40jlt4
Re: KNX interface
Got my SM card reader today.
The SM card has a view .bin files:
CONN_000.BIN
INST_000.BIN
CHAN_000.BIN
PROD_000.BIN
CONFIG.000
Is this something that ETS would read?
I'd say no if I check this link:
https://www.knx.org/ie/software/ets/man ... /index.php
USB stick looks interesting. Would this, combined with ETS be able to "read" the current configuration? Or do I need those .bin files, which seem hager specific to me.
The internet is not really helping me in getting info regarding those files.
The search continues...
CONN_000.BIN
INST_000.BIN
CHAN_000.BIN
PROD_000.BIN
CONFIG.000
Skippiemanz
Re: KNX interface
Nope that doesnt look like ets files.v40jlt4 wrote:Got my SM card reader today.
CONN_000.BIN
INST_000.BIN
CHAN_000.BIN
PROD_000.BIN
CONFIG.000
The ets and interface wil show you the group adressen but not the names and parameters of the knx device so pretty useless im afraid.
