For https://www.domoticz.com/wiki/Mindergas.nl
I need to install autotools to execute JQ and without autotools it seems I have a situation.
./post-mindergas.sh: line 8: jq: command not found
Unfortunately
$:sudo apt-get install autotools –y gives an error:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package autotools
E: Unable to locate package –y
The OS is up to date, also the firmware.
I’ve already installed JQ 1.5 successfully
and autotools-dev is installed too.
What could be the problem?
JQ autotools install error
jvilly
- Domoticz version: V.3.4834
Re: JQ autotools install error
Did you find a solution for this?
I have the same error but only when I try to install Daikin interface with Domoticz:
https://www.domoticz.com/wiki/Daikin_wifi
Same situation, I get the error
pi@raspberrypi:/etc/network/jq$ sudo apt-get install autotools -y
Anyone a solution for this?
Raspberry PI 3 / Domoticz / RFXCOM433E / KAKU / Promax
