Electricity meter issue
Pinguin
Post by Pinguin »
Good evening, I have an issue and cannot find a solution.
I have an powermeter with a led pulsing 1000 times/kWh.
I installed an optical sensor connected to a ESP07 running ESP easy.
I have a graph with a point every 5 minutes, but the value in watts is wrong (60 times too small and no decimals).
I created a second sensor in domoticZ / ESP Easy with the same physical sensor.
Now the value in watt is OK but I have only a value per hour.
How can I configure domoticZ to have a sample per 5 minutes with the right value ? What's wrong ?
thanks in advance to all
Pinguin
Re: Electricity meter issue
Post by Pinguin »
Sorry for mixing figures.
The yellow is the 5 minutes sample rate with wrong values and the blue the 1 hour sample rate with real values
Pinguin
Post by Pinguin »
Thanks for your answer.
Does it exist a solution to have on the blue curve 1 sample every 5 minutes, in place of 1/hour, just to have enough pulses for an acceptable precision ?
RidingTheFlow
Post by RidingTheFlow »
I don't think Domoticz supports this unfortunately.
Though I'd like to have such feature too. Generally I have ~10-20 pulses per 5 minutes. Multiply this by 12 (60/5) and this will give a wattage with good enough precision at least to see when energy-hungry devices (fridge, oven, boiler etc) switch on and how much power they take.
Count per hour is just too low resolution and limits usefulness of reports.
gordonb3 wrote:The graphs are a nice gimmick to show trends but you should not expect them to show any real values, particularly with hardware that shows such crude information.
Edit: actually pulse meter indicator is PWM-like device, and there is nothing "crude" about it, it actually can provide quite accurate data.
Since its PWM, "instant load" could be approximated as:
(Instant load at this pulse in Watts) = (Wh per pulse)/(hours since last pulse)
Obviously it will be as precise as pulse frequency - actually it will be more precise when power consumption increases (and when it actually matters most).
RidingTheFlow
... and as a proof that its totally possible to make simplest Wh pulse meter to act as accurate Watt-meter I've made a script, which you can see in its dedicated thread - viewtopic.php?f=32&t=11315
