Kevin Smart Thermostat
kvanhoorn
Post by kvanhoorn »
Hi guys,
Here is a peak into my home made Thermostat.
I have a heater that only has the on- and off option, that makes it easy to control.
I removed the old Honeywell thermostat and connected the wires to a relay and GPIO of the Raspberry Pi.
Than I used the hole in the wall to provide the iPad with power.
This is my script: https://github.com/kvanhoorn/domoticz/b ... ostate.lua
See the pictures for the hardware.
Dashboard on iPad
Dashboard on iPad
Hardware behind iPad
Hardware on RaspberryPi
kvanhoorn
Re: Kevin Smart Thermostat
Post by kvanhoorn »
And here are two screenshots of the dashboard and the devices in Domoticz.
Screen Shot 2016-03-12 at 11.48.24.png (75.19 KiB) Viewed 2262 times
Screen Shot 2016-03-12 at 11.57.01.png (91.64 KiB) Viewed 2262 times
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Looks nice! Have a sort of same setup with a Samsung tab on a brodit holder and a WiFi thermostat connected to the boiler. I will take a look at your script.
Verstuurd vanaf mijn SM-G925F met Tapatalk
codesnipper
Post by codesnipper »
I was just looking for something like that, but for control 4 electric heaters and water heater. Is it possible to modify it for working in selected hours?
kvanhoorn
Post by kvanhoorn »
codesnipper wrote:I was just looking for something like that, but for control 4 electric heaters and water heater. Is it possible to modify it for working in selected hours?
Yes, I have a virtual switch that says "Night". This virtual switch is set to On and Off via a timer script, so you could use it to control your heaters with it when the switch in on.
