I use domoticz and MySensors on LAN gateway, and it is working great (like everything else, most of the time
Today I noticed one strange thing, I have one Temperature+motion+lux sensor that is battery operated, and I have recently changed the batteries in it, but after a week Domoticz stopped getting the data from the sensor. I checked the data using MYSController, a windows tool that will show raw communication data between sensors and gateway, and data was coming, I measured voltage on the arduino pro mini and it was 3.3v as I have a booster, but there was just no data in domoticz, for like two days. I replaced the pro mini and the radio, but still no data. After two days of headbanging and going trough the usual "fck it I'm going back to cable" I heard a shhhhhus sound from the sensor, and have found that one battery was leaking. After replacing (what I thought was new battery) the sensors appeared again in domoticz.
Now a funny question, how come I did see sensor data in MySController, but not in the domoticz? Domoticz logs were empty all the time?
I do not have raw logs unfortunately, and this as happening in the period when the domoticz recently updated (great update btw) so I did cleanup the domoticz database as well, removed the mysesors module in order to try to fix the "battery" problem.
Did anyone experienced this?
