Telnet Type Data to Domoticz Help Topic is solved
Everything about esp8266 and more.
NickHead
Re: Telnet Type Data to Domoticz Help
Post by NickHead »
Managed to get the Socket on the PI Simon.
Tried the same program on the Domoticz LUA, worked in a fashion, however, due to the program
needing to be connected to the Bridge, it was connecting every time it was polled.
I have to find a way now to connect it, and keep the connection.
>lua -e "io.stdout:setvbuf 'no'" "ESPInverter.lua"
Connected to ESP Bridge on	192.168.0.207	PORT	23
Ginlong 1K Inverter
Inverter Terminal ID 7E02A1 received
DC Voltage 1     135.3 Volts (Side Panels)
DC Current 1     0.2 Amps
Grid Voltage     237.1 Volts
Grid Current     0 Amps
Grid Wattage     0 Watts
SP Wattage    1K 27.06 Watts
Not Utilised     398
Grid On/Off      0
This Month kWh   70 kWh
Last Month kWh   17 kWh
AC Frequency Hz  50.02 hZ
Country Standard 1
Power Curve      4
Inverter Status  00000283
Inverter State   0000
Extra Bits       31002F000008520150127320
And the output is more standard/readable rather than hex digits.
This is still running on the PC, through the wireless bridge.
A lot of stuff that is doing my head in.
NickHead
Post by NickHead »
Update: Slowly getting there bit by bit
DC Voltage 1     139 Volts (Rear Panels)
DC Current 1     0.6 Amps
SP Rear Watts    83.4 Watts
DC Voltage 2     143.8 Volts (Front Panels)
DC Current 2     0.5 Amps
SP Front Watts   71.9 Watts
SP Wattage  2K   155.3 Watts
Grid Voltage     242 Volts
Grid Current     0.5 Amps
Grid Wattage     121 Watts
Capability       00 00 34
Software Version 7  (07)
Grid On/Off      0
AC Frequency Hz  50.01 hZ
Power Curve      4
Inverter State   Generating
Temperature      18.6C
Efficiency       77.91	%
Power Today     5.8 kWh
Grid Combined   0.19	kW
Combined Power	1930	kWh
Power Yesterday 3.2 kWh
Total Power     1280 kWh
This Month kWh  85 kWh
Last Month kWh  24 kWh
NickHead
Post by NickHead »
Update:
Decided LUA was not easy enough to use.
Ported it over to Python, Job Sorted, took some time to reverse engineer what I had already
but it's working. Few final polishing routines to create and game over. off to do something new
with the gear..
simonrg
Domoticz version: 3.8807
Post by simonrg »
Glad you have got it all working.
Curious to understand what the Python looks like, it would be a nice example to post up on the http://www.domoticz.com/wiki/ESP8266_WiFi_module.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
NickHead
Post by NickHead »
Still in " Sorting it out mode". Tightening all the slack programming out as best I can.
Limited time after work as there is no sun and nothing comes from the inverters, so I
have to do it on sunny day and they are few and far between here at the moment.
It's working in a fashion but I just can't keep it logged in when the sun goes down. The program
flags an error, if I can sort it out it will be use-able.
Just been trying a python inverter simulator I wrote, need to run it on another pi really as the RS485 converter
is not knowing whether it's coming or going.
NickHead
Post by NickHead »
Here's a picture of the circuit I made.
An ESP-Programmer/breakout that I use.
ESP-8266-01, RS485, Power Dropper, Reset and Program buttons
with headers for GPIO and RS232 in/out.
[img]
[/img]
simon_rb
Post by simon_rb »
This looks like what I was hoping to do with my denon amp. I need to pole the power state of the amp by sending the command PW? And read the reply and if it's on then switch a switch in domoticz to on. That's it in its simplest form.
Any ideas?
Cheers
NickHead
Post by NickHead »
Do you know what the data-stream format is ?
For my inverters I have a print out of the commands in RS485 format.
I started with a simple ESP Bridge from wifi-tcp but I changed it over to a commercial Wifi-Serial-Ethernet bridge, it
doe the same thing but all in one and has 2 serial ports, works like a dream and frees the ESP for something else.
You need the protocol first then write the program to see if it decodes/encodes it.
I am not an expert on programming I just do a lot of asking and trial / error .
simon_rb
Post by simon_rb »
I think its pretty simple, below is the documentation I found. Thank you :)
http://openrb.com/wp-content/uploads/20 ... V7.6.0.pdf
NickHead
Post by NickHead »
Wow, that's a pretty comprehensive list.
Too late for me to ingest at the moment, I will look tomorrow and see if I
can be of any help to you.
Off to bed.
simon_rb
Post by simon_rb »
I just need to send the PW? and get Domoticz to understand and act on the reply.
Thank you very much! Sleep well. :)
NickHead
Post by NickHead »
Do you know what data is sent from the Denon after PW? has been sent to it.
I am assuming you have an IP Address for it, and a Port Number.
I can send PW? over the network to an IP/Port. Depending on the result received is what
determines what happens next.
I cannot drop out of a Python Loop without knowing what is received, even better if its a CR then
the length is/can be fixed.
simon_rb
Post by simon_rb »
Yes I have an IP address and port but how can I send the command and let you know what the answer is?
NickHead
Post by NickHead »
You will need the libraries installing, and the Denon/Domoticz Parameters modifying.
#!/usr/bin/env python
import os
import sys
import socket
import urllib, urllib2, hashlib
# Denon Amp Settings
denon_host = "192.168.0.231"
denon_port = 8081
#domoticz settings
domoticz_host         = '192.168.0.5'
domoticz_port         = '8080'
domoticz_url          = 'json.htm'
port = 8080
def CallData():
	Text = "pw?"
	s.send(Text)
try:
	s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    		print "			 Socket successfully created"
except socket.error as err:
		print" "
s.connect((denon_host,port))
print "                      Host =",denon_host," Port = ",denon_port
print "			 Connecting to Denon Amplifier"
CallData()
NickHead
Post by NickHead »
P.S
The program will not actually receive anything.
It just sends pw? to the Denon.
If I don't know how the data is formatted, I cannot do anything to continue.
As I said, I am no expert on this, only been programming a few months
NickHead
Post by NickHead »
needs changing to
s.connect((denon_host,denon_port))
simon_rb
Post by simon_rb »
Thanks for that, I am just trying to find out what the Denon would return so we can act on it. Must be a way of sending the PW? and view what is returned.
NickHead
Post by NickHead »
There is, but I aint done that yet, and wether it would work is another story.
You could always try entering other commands in to the text string to see if it changes channels/volume or whatever/
I simple read of about 10 bytes would suffice I would reckon.
i am doing too many things here at the moment , I have to rewrite my SolarPanel programs as well
not only that , I have to to work in a bit :(
NickHead
Post by NickHead »
This will/should receive 6 characters from the Denon Stream.
It will print the character chr(DA[Data}) 6 times. with the associated Decimal Number Next to it.
Its a start.
import os
import sys
import socket
DA = [1,2,3,4,5,6,7,8,9,10,1,2,3,4,5,6,7,8,9,10]
denon_port = 8080
#domoticz settings
port = 8080
def CallData():
	Text = "PW?"   # Changed as it was lower case
	s.send(Text)
def ReceiveData():
	DStart = (s.recv(1))
	for Data in range ( 1 , 6 ):
		DA[Data] = ord(s.recv(1))
		print chr(DA[Data])," ",(DA[Data])
try:
		print" "
CallData()
ReceiveData()
simon_rb
Post by simon_rb »
Does this help, it uses the PW? As an example...
https://www.npmjs.com/package/denon-avr
