Database conversion to latest Domoticz version
ARichter
Post by ARichter »
Hallo,
I am Andreas and using the Domoticz version 1.0.10. on a Raspberry Pi since a long time without any problems. To update the system I would like to install now the newest version of Domoticz.
My question is:
Is it possible to convert the old database including my settings and all information about switches, blinds,... to the database of the latest Domoticz version or did I have to input all old information manually.
Thank you for your support
Andreas
jkimmel
Domoticz version: 2021.1
Re: Database conversion to latest Domoticz version
Post by jkimmel »
Just update and you are fine.
Rfxcom
Raspi 4
ARichter
Post by ARichter »
Thank you for your quick reply.
The old version has no update function in the menu, so I have to install the new version but copying the old database (domoticz.db) to the new version does not show any settings.
gizmocuz
Post by gizmocuz »
The database will be automatically converted to the latest
But make sure you make a complete backup of the domoticz folder so you can always go back
ARichter
Post by ARichter »
Please let me know how I can update this old version because the command ./updaterelease does not work.
Thank you for your help.
gizmocuz
Post by gizmocuz »
Why, what is the output ?
ARichter
Post by ARichter »
The respond is: command not found
gizmocuz
Post by gizmocuz »
please follow the wiki how to install the stable (perform the same action to update)
http://www.domoticz.com/wiki/Installing ... spberry_PI
ARichter
Post by ARichter »
Sorry but this fails. It seems that it overwrites the database and when the program starts it will only show the setup menu.
gizmocuz
Post by gizmocuz »
No it does not
ARichter
Post by ARichter »
You are right the files is still there but how can I load the data in the program?
gizmocuz
Post by gizmocuz »
Just start the program
