I have an RFXtrx433 and an Aeotec ZStick S-2 installed in my Pi. The RFXtrx433 has the Byron SX, AC and Oregon Scientific protocols enabled.
The two seem to work OK together and I have correctly working devices on both, however I have a problem with an OWL CM113 and a single utility sensor attached.
The OWL CM160 sees the CM113 OK, but for some reason, Domoticz sees the CM113 as a ZWave device rather than an RFXCom device. Consequently (I assume), all the values it reports are wrong. See below.
The S-2 knows nothing of the CM113 in it's hardware table. I've tried deleting the devices but they just re-appear.
Any ideas?
Gareth
OWL CM113 showing up as ZWAVE device with wrong readings
garethhowell
- Domoticz version: 3.9317
- bbqkees
- Domoticz version: 4.1x
Re: OWL CM113 showing up as ZWAVE device with wrong readings
Probably these are reported devices from an actual ZWave node.
Do a search in the all devices list with '701'. The actual node might show up too.
Your Owl could still be in the unused devices list.
garethhowell
Don't think so. I went through the list and deleted all the old devices that got added whilst I was tinkering about. What I didn't show in the screenshot was that it was last seen just before I took the shot, so it's an active device.
There's nothing in the unused list that is relevant.
