Can anyone recommend a simple digital thermostat that works with domoticz and uk heating systems.
Ive currently got a Honeywell CM907 programmable thermostat which operates my combi boiler but want to replace this with a basic one that i can control the temperature with via domoticz.
Would something like a Horstmann HRT4B-ZW Battery Powered Wireless Electronic Room work?.
Any recommendations?
Thanks.
Thermostat in the Uk
- Westcott
Re: Thermostat in the Uk
Yes, any of the Horstman (or 'Secure') xx-ZW thermostats work, but only when paired with an ASR-ZW switch.
Domoticz doesn't seem able to hear the call for heat from the thermostat, but can operate the switch.
Thanks for the reply..
Forgot to add. I need it to work with the rfxcomm ?
Is domoticz able.to set the temperature on the stat? I'm using a relay at the moment to switch the heating on and off but want to be able to set the temperature too so I'd be purchasing the stat and the control unit.
- Westcott
The Horstmann xx-ZW range are Z-wave devices.
You'll need to look for 433MHz RFX devices.
