I'm a new Domoticz User, an I was unable to find the ansers in this forum... Maybe someone can help me.
Question : I wish to know if someone had succeed in using Novatys Wall Switch ? They're correctly detected, but the "On trigger" of the wall switch is identified on one device and the "Off trigger" is another device. So, the two triggers send "On" on differents Domoticz devices... As a result, it's impossible to use the wall switch to control something with Domoticz...
Is there a trick to tell Domoticz that the second device is the "Off" position of the first device or do I need to send debug logs of the signals ? I've checked and novatys wall switch are supported on the R37 of the RFLink Gateway. (viewtopic.php?t=9944)
My goal is to use this wall switch to command a lamp connected on a non-novatys device (instead of being controlled with the original "ugly" remote).
Thanks.
Novatys Wall Switch - How do they work ?
- Domoticz version: 2.3530
RPIv1 on 2.3530 - RFLink R37
Re: Novatys Wall Switch - How do they work ?
I'm interested too
Tjanks
Tjanks
- Stuntteam
Not every model of Novatys has been tested (yet)
Please send debug data of your remote signal (including button number etc.) to [email protected]
So we can correct it as soon as possible.
Thanks. I'll do it as soon as possible. (I hope this weekend)
I do it yesterdaylalmat wrote:Thanks. I'll do it as soon as possible. (I hope this weekend)
Ok, i've sent my log too. Hoping it helps !
I can make more debugs if needed.
