Hi RFXcom,
I know that the 1byone driveway motion sensor and receiver is not listed as supported.
http://www.1byone.co.uk/Home-Security/Alarms/O00QH-0511
However, I'm just about to buy a set, and would like to help get them included.
UPDATE!
The sensor is detected immediately as a SelectPlus Chime -
Packettype = Chime
subtype = SelectPlus
Sequence nbr = 4
ID = 004E90
Signal level = 7 -64dBi
However, if I try to transmit a chime using RFXmngr it crashes with -
************** Exception Text **************
System.OverflowException: Arithmetic operation resulted in an overflow.
at RFXmngr.frmMain.28AAA(Object ᙂ, EventArgs 1AAAA)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8670 (QFE.050727-8600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
RFXmngr
Assembly Version: 18.0.0.0
Win32 Version: 18.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/RFXmngr/RFXmngr.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.8670 (QFE.050727-8600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
RFXtrx433e with 1byone driveway motion sensor and receiver
- Westcott
planetf1
Re: RFXtrx433e with 1byone driveway motion sensor and receiver
Similar here, I just posted to viewtopic.php?f=17&t=5121&p=77312#p77312
My unit is the OUKQH-0499. the sensors (pir) are detected fine but I can't figure out how to pair the alarm...
- Westcott
Hi planetf1,
I'm trying to remember how I did it.
You can't 'pair' the alarm, all you can do is send a copy of the detector.
I think I created a manual switch, switch type doorbell, type ByronSX.
Then I set the ID to the same as the detector, and tested it.
Perhaps if the alarm is in pairing mode, you could send a different ID.
planetf1
I had hoped I could manual add a switch and send whilst the alarm was in learning mode, but this didn't seem to work.
I can indeed send a copy of a paired device (so far I've just tried this with rfxmngr) but how do I "unpair" the PIR sensor (I emailed 1byone to ask about unpairing)
I want to decouple the alarm from the pir sensor, and allow domoticz to make that call....
In truth the alarm isn't critical -- it was the cheapest way to buy the sensor -- but it seems a shame it doesn't work!
- Westcott
The instructions mention something about -
5. Press the auto-learn button and hold for 5 seconds.
This deletes all learnt codes.
planetf1
Good and bad news
Firstly I was able to create a new "switch" to specifically activate the chime without a PIR trigger. I did this by directly editing the DeviceStatus table in sqllite, and copying one of the PIR sensors with a minor modification to the unit ids. Pressing this did nothing (correctly) until I hit learn on the receiver, and then it would kick the chime off. Grest!
However still no joy unlearning the PIR sensors. they seem to retain their id over a battery replacement so I'm awaiting another email back from 1byone. They said the same as @westcott (which I don't see in my instructions) but I cannot get the ids forgotten despite leaving the chimes in a closed room
- Westcott
It worked for me when I held the auto=learn button down 'til it went beep.
