I currently have a fibaro wall dimmer (FGD212) and use S1 to turn on/off the lights.
I want to add S2 so i can turn a scene on/off
In a scene there is a posibility to add an activation device but this turns the scene on once, i can not toggle(eg 1 press on, 1 press off)
is there a way to use S2 as a toggle switch for a scene and/or light?
if this is not possible do i need to make multiple scenes to do this(eg 1 click, scene-on, 2 click scene2-off
thanks
fibaro dimmer use S2 to toggle light?
Szwuntex
Re: fibaro dimmer use S2 to toggle light?
Maybe this thread can help you?
http://www.domoticz.com/forum/viewtopic.php?t=6995
Gravityz
- Domoticz version: 2025.1
Thanks,
that partially helped me
i also found a thread myself which talks about the toggle functionality.
viewtopic.php?t=8357
i will do some experimenting
