PIR-sensor/bewegingsmelder Home Security Aliexpress
kvanhoorn
Post by kvanhoorn »
Does anyone have experience with these sensors?
http://nl.aliexpress.com/item/Free-Ship ... 77500.html
I contacted the supplier a couple of times, but their English is that bad that I'm not able to communicate with them.
So, anyone any good experience with Domoticz and the cheap motion sensors?
Kind regards
ThinkPad
Re: PIR-sensor/bewegingsmelder Home Security Aliexpress
Post by ThinkPad »
They will work, see this topic: http://domoticz.com/forum/viewtopic.php ... 262#p32296
Be sure to get the 4333Mhz version, not the 315Mhz.
But be aware of the fact that those PIR's only send a on signal, so you will need a 'off delay' in Domoticz.
And they also seem to use quite a bit of power, resulting in empty battery quite fast: http://domoticz.com/forum/viewtopic.php ... 180#p50660
kvanhoorn
Post by kvanhoorn »
@ThinkPad I saw that topic earlier, but wasn't shure if the PIR motion detectors were compatible too. Do I also need to change some jumpers or alter the chip or is it plug and play?
kvanhoorn
Post by kvanhoorn »
Maybe I should start with two just in case. 433 Mhz Home Alarm System Wireless PIR Sensor / Motion Detector - 2 Pack
http://www.aliexpress.com/item/433mhz-h ... 30901.html are these the same protocol?
ThinkPad
Post by ThinkPad »
If you get one with a PT2262 or SC2262 chip, it will work with RFXCOM. But you can only be sure if it is mentioned in the product description. Hard to tell from only a picture of the complete unit ;)
Best to see if you can find a link from the topic i mentioned, and order them from that seller.
jarwis
Domoticz version: 2.3530
Post by jarwis »
I've bought 433MHZ Wireless PIR Motion Detector for Home Alarm Home Security from Banggood.
http://www.banggood.com/433MHZ-Wireless ... 52710.html
Package:
https://goo.gl/photos/pvKBphXmjffr4ZL57
Opened, circuit visible:
https://goo.gl/photos/gYpsP2EqyEkfgVrJ9
Circuit, front side:
https://goo.gl/photos/pYF7HHStXpjnesuRA
Circuit, back side:
https://goo.gl/photos/nSDb72dU3s14U7QG9
PROs:
  • Cheap, 10,94 euros
  • Works with RFXtrx433E and Domoticz
  • Jumper for setting LED off
  • Possibility to set alarm delay (5 sec, 50 sec or 5 min)
  • The package includes 10 spare jumpers
CONS:
  • Long delivery time (48 days to Finland)
  • Sends only ON command (need to use OFF delay)
  • Instructions don't explain Code Jumper settings
  • Difficult installation
I had no idea how to set Code Jumpers so I copied to settings from here: http://domoticz.com/forum/viewtopic.php ... =40#p17076
The above jumpers settings show up in Domoticz as:
25 RFXtrx433E FF5515 0 Liiketunnistin Lighting 4 PT2262 Off 7
Lighting4 protocol must be enabled in RFXtrx433E.
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
This 433.92Mhz wireless motion sensor works fine with RFXCOM RFXTRXE as Lighting4
PT2262 chip
Battery Type: DC 9V
External Power Supply: DC12V
9meter detection
(model AFT-701)
http://www.aliexpress.com/item/433-MHz- ... 18695.html
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
Lucmaas
Post by Lucmaas »
My PIR sensor wont be detected by domoticz is this one supported? I got an RFXCOM - RFXtrx433
Alie link: (https://nl.aliexpress.com/item/Free-Shi ... 4c4dTvHRDG)
Lucmaas
Post by Lucmaas »
Yes I already tried extending the antenna.
b_weijenberg
Post by b_weijenberg »
Check with only Lighting4 enabled.
If it does not operate contact rfxcom.com
RFX-433, RFX-433EMC, RFX-868
Lucmaas
Post by Lucmaas »
b_weijenberg wrote: Thursday 09 August 2018 19:21 Check with only Lighting4 enabled.
Thanks Worked now :)
