Somfy Centralis RTS
433Mhz opensource Receiver & Transmitter.
Willem81
Somfy Centralis RTS
Post by Willem81 »
Good afternoon!
I have a RFlink with latest firmware, Raspberry and Domoticz.
I have two roller shutters, which use a Centralis RTS remote to be controlled.
I would like to control the roller shutters also from Domoticz.
I tried to "automaticly learn" the Centralis RTS signals, but that didn;t do anything.
Is the Centralis RTS not supported (yet) ? Or maybe I am doing something wrong? On the backside of the Centralis RTS is a Programming button. I tried to press this, but only thing happens is the roller shutters confirming that they received the signal (opens and closes to acknowledge). After that the Somfy roller shutter motors are waiting for any remote to send a signal to pair, but I do not seem to get that working. Also: Somfy RTS is not in the "Manual Switch" list in Domoticz. Which one should I take? RFY like RFXcomm? The Somfy motor does not reply to that :(
Any help would be appreciated!
Last edited by Willem81 on Saturday 27 February 2016 16:57, edited 2 times in total.
Willem81
Re: Somfy Centralis RTS
Post by Willem81 »
Hmm... Maybe this can be the issue:
http://www.domoticz.com/forum/viewtopic.php?t=10331
Willem81
Post by Willem81 »
Updated to latest Beta. No change :(.
What I did try is to attach the rflink to a pc and enabled serial port logging and debugging. The RFlink does not report any activity when the Somfy Centralis Remote buttons are pressed. I checked the manuafacturers page and it should be 433Mhz (from the dutch site):
" De handzender en/of draadloze schakelaar zendt hoogfrequente bedieningssignalen (433,42 MHz) naar de ontvanger. "
Willem81
Post by Willem81 »
nobody :( ?
Stuntteam
Post by Stuntteam »
No idea if Centralis is supported.
- Use rflink loader with logging and debug enabled
- Make sure there is acommunication (you see pulses appear from other devices)
- Hold the Centralis remote at about 1 meter away and press a button
If you did not see any signals appear on the debug screen when pressing a button, then it must be incompatible.
