Hi, trying to recover my Domoticz which fails in a segmentation fault now I seem to get lost in finding the right link.
Somewhere in a subject the needed file was domoticz_linux_armv61.tgz and in the wiki its domoticz_linux_armv71.tgz
However, both files seem not to exist. I assume there is a newer version, but how do I find out what the latest version is ?
Thanks,
Ben
domoticz manual install on Pi
paulvha
Re: domoticz manual install on Pi
you could use this article : https://www.domoticz.com/wiki/Installin ... spberry_PI
zanco
Thanks for your reply. I did use that link. On the other hand, the problem was that without SSH I had to manually type the URL and I have mistaken the l for a 1 , so I used armv71 instead of armv7l
However, completing the instructions without any error still gives me a Segmentation fault then starting domoticz wiht sudo service domoticz.sh start
Any clue on that ?
Thanks,
Ben
Any clue on that ?
Thanks,
Ben
zanco
I notice at Pi boot that even ntptime gives a segmentation fault. Guess the SD card is corrupt.
Currently backing up the DB and config and hope that's enough to save me from starting from scratch again.
Regards,
Ben
Regards,
Ben
zanco
Formatted the card. Burnt a new image. Booted OK, changed network settings and password.
After reboot I could access Domoticz without a problem. Could import the database and all is running without having to setup anything again.
Thanks,
Ben
Thanks,
Ben
