[MyDomoAtHome] Support thread
- Domoticz version: 2.4538
Re: [MyDomoAtHome] Support thread
Tok a recovery to backup for before i installed MyDomoAtHome and try'd again, like this:
cd domoticz
git clone https://github.com/empierre/MyDomoAtHome MyDomoAtHome
cd MyDomoAtHome
cp config.yml.def config.yml
changed this files:
Config.yml:
domo_path: "http://192.168.1.123:8080"
external_url_camera : "http://ip:port/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=&pwd="
volumio_path: ""
(no need to change anythinh with IP-camera? Edited domo_path IP)
start2.sh:
export PERL5LIB='/home/flemmingss/domoticz/MyDomoAtHome/lib/'
(edited username)
MyDomoAtHome.sh:
APP_DIR="/home/flemmingss/domoticz/"
(edited username)
config.yml.def:
volumio_path: ""
(edited ip at domo_path)
sh ./run-once.sh <-and yes to all
Still have same problems to start the service..
(the server is a VMWare esxi server, with 64bit Ubuntu server as OS)
cd domoticz
cd MyDomoAtHome
changed this files:
Config.yml:
volumio_path: ""
start2.sh:
(edited username)
MyDomoAtHome.sh:
(edited username)
config.yml.def:
volumio_path: ""
SOLVED.Doler wrote:Hmm...epierre wrote:looks we had this issue on another VM try... no clue why...
If I do "dpkg -l | grep cpan" I get " libcpan-meta-perl (Perl module to access CPAN distributions meta data)" as a result. So there is something available? Could it be that the path is not correct? "echo $PATH" gives "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games", maybe there is something missing?
Thanks, Mark
Problem appeared to be a missing cpanminus. After some internet searching I installed that using:
sudo apt-get install curl gcc-4.7
sudo curl -L http://cpanmin.us | perl - --sudo App::cpanminus
- Spoiler: show
- Spoiler: show
pi@raspberrypi:~/domoticz/MyDomoAtHome $ ps ax | grep starman
6236 ? S 0:06 starman master
6262 ? S 0:00 starman worker
6263 ? S 0:00 starman worker
6264 ? S 0:00 starman worker
6265 ? S 0:00 starman worker
6582 pts/0 S+ 0:00 grep --color=auto starman
Grtz, Mark
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
- epierre
@Doler the issue is that you're on a repository that does not seems to have all modules... this one is not cpanm it is just the minimum basic...
tyry this:
curl -L https://cpanmin.us | perl - --sudo App::cpanminus
perl -MCPAN -e shell
then input:
install Time::Moment
install App::cpanminus
we'll if it can work
tyry this:
then input:
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
- epierre
@Doler oops funny you found out, great !
@Evelen same punition as above to make it work, then end is near
Did this:
yes
sudo
yes
exit
It works
Also found the MyDomoAtHome on http://192.168.1.123:3001/
rebooted, still works
EDIT: Well, not 100%
http://192.168.1.123:8080/json.htm?type=devices <-can see devices
http://192.168.1.123:3001/ <-works
http://192.168.1.123:3001/devices <- hmm, this changes every refresh
Also ImperiHome say "Unable to connect to Domoticz", but it looks like it find "MyDomoAtHome"
yes
sudo
yes
exit
It works
{"devices":[{"id":"S00","type":"DevGenericSensor","name":"Unable to connect to Domoticz","params":[{"key":"Value","graphable":"false","unit":"","value":"http://192.168.1.123:8080"}]},{"id":"S01","type":"DevGenericSensor","name":"Please add this gateway in Setup/settings/Local Networks","params":[{"value":"","unit":"","graphable":"false","key":"Value"}]}]}
- epierre
@Evelen now this is a configuration problem, have you set a login/pass in domoticz ?
also you must rename config.yml.def to config.yml (as said in tutorial)
I got this error when trying to start service (./start2.sh)
so i did a ./run-once with this result "Unable to locate package libdancer2-perl"
so i did a ./update-mdah.sh
again with E: Unable to locate package libdancer2-perl and some other errors.
Hope someone have an idea on how to solve this?
Error while loading /home/pi/domoticz/MyDomoAtHome/bin/app.pl: Can't locate Dancer.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 19.
Will update packages list first...
Now getting the needed software...
Now getting getting and installing dependencies...
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'perl' instead of 'libtime-piece-perl'
libcrypt-ssleay-perl is already the newest version.
libdatetime-format-strptime-perl is already the newest version.
libdatetime-perl is already the newest version.
libjson-perl is already the newest version.
libplack-perl is already the newest version.
starman is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
libdbd-sqlite3-perl is already the newest version.
libdbi-perl is already the newest version.
sqlite3 is already the newest version.
libaudio-mpd-perl is already the newest version.
libnet-upnp-perl is already the newest version.
libpoe-component-client-mpd-perl is already the newest version.
Time::Moment is up to date. (0.38)
Now installing the service
update-rc.d: using dependency based boot sequencing
Stoping MyDomoAtHome service...
[....] Stopping plack server: MyDomoAtHomestart-stop-daemon: warning: failed to kill 3115: No such process
failed!
Retrieving latest code...
error: cannot open .git/FETCH_HEAD: Permission denied
Checking latest libraries dependencies...
whiptail is already the newest version.
Restarting MyDomoAtHome service...
- epierre
@PappleD Dancer2 should have been an evolution, this is where I dropped dancer and I am rewriting it in nodeJS, so no issue there.
I don't understand why it has disappeared, but this line should fix it (is in run-once also...):
sudo apt-get -y install libdancer-perl
yepp, so one step furtherepierre wrote:@Evelen now this is a configuration problem, have you set a login/pass in domoticz ?
anyway, I have both files, and i have edited them so them are the same: (do i need to delete the .def file?
Also, YES, i have a username and password for domoticz.
Anyway, looks like this worked: (localhost or 127.0.0.1 did not work, idk why..)
- epierre
so as said in the tutorial add 127.0.0.1 or the ip to the local networks in domoticz
- Domoticz version: V2.3530
I have exactly the same issue. Running the above doesn't help. I get this error:epierre wrote:@PappleD Dancer2 should have been an evolution, this is where I dropped dancer and I am rewriting it in nodeJS, so no issue there.
pi@raspberrypi ~/domoticz/MyDomoAtHome $ ./update-mdah.sh
[ ok ] Stopping plack server: MyDomoAtHome.
Already up-to-date.
[ ok ] Starting plack server: MyDomoAtHome.
Update path finished
[FAIL] MyDomoAtHome process is not running ... failed!
And this is if I try to do ./start2-2.sh manually:
pi@raspberrypi ~/domoticz/MyDomoAtHome $ ./start2-2.sh
Error while loading bin/app2.pl: Can't locate Dancer2.pm in @INC (@INC contains: /home/pi/domoticz/MyDomoAtHome/bin/../lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/pi/domoticz/MyDomoAtHome/bin/../lib/Domo2.pm line 20.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/bin/../lib/Domo2.pm line 20.
Compilation failed in require at bin/app2.pl line 7.
BEGIN failed--compilation aborted at bin/app2.pl line 7.
- epierre
@nicolai do not use start2-2.sh just Start2.sh. I will remove the other for it creates confusion. The message is not an error in the end.
following what the start2.sh says, you may need:
and/or
sudo curl -L https://cpanmin.us | perl - --sudo App::cpanminus
and relaunch the run-once.sh
for the 2nd, do a git pull first, I have added it in the run-once.sh
and/or
- epierre
it really depends on which network "card" your system will use...Evelen wrote: Anyway, looks like this worked: (localhost or 127.0.0.1 did not work, idk why..)
- epierre
@all sorry for those moving dependencies issues... used to work, not working for some... the definitive solution is comming with the nodeJS version, all is there except graphes and testers are already welcome
I am setting a slack channel for this on https://mydomoathome.slack.com to make support quicker and miss no message
so please send me your email so I can invite you !
Epierre, really appriciate your support and all the work you are putting into this. Please add me to your slack channel -
- epierre
thanks nicolas, for people interrested and if you don't want to see your email on a forum please mail me on [email protected]
Thank you Epierre for your help.
It did not work unfortonaly, but someore i else i found something i tried. and that succeed!
i did: sudo cpanm Task::Plack
and after that my errors were fixed and i was able to start MyDomoAtHome.
And now i can you switch my light with my app! "dancing"
now i'm going for outside network support... fingers crossed
I must say I am not very impressed with imperihome. No "Push on button" and "Push off button", you can not change the text size, there are only two themes, very few icons, and those are reasonably low, and only a few are dynamic.
generally very little opportunity to do things cosmetic fine.
In addition, one must have this Imperihome menu bar at the top.
Well, there's no better alternatives to Domoticz, so get well live with Imperihome.
Anyway, MyDomoAtHome has worked fine until now.
Some things I would have liked:
- RGBW lights control
- epierre
hello,
go to rhe custom mode, yoy can do all that even your own tbeme or home picture.
rgb is an issue in fomoticz I've not yet sorted out...
