Adjustement Temperature wemos + DTH22 Topic is solved
Qcvictor
I use wemos D1 mini with her dht22 shield, everything work as expected, but position shield just above the ESP give me 3 degre offset, so I want use the adjustment for operate correction, unfortunately when I apply this adjustment nothing happen!
simonrg
- Domoticz version: 3.8807
Re: Adjustement Temperature wemos + DTH22
You don't say which ESP8266 firmware you are using on your Wemos D1 Mini.
Assuming you are using the ESPeasy firmware, then under Devices / DHT22 edit - in the formula box enter:
if 3 degrees too high then:
if 3 degrees too low then:
I have just got 4 DHT22 sensors, I have attached them to one Wemos D1 Mini and I am sending all 4 values back to Domoticz, just playing with offsets to understand how accurate / reproducible the measurements are.
ESPeasy is well documented here: http://www.esp8266.nu/index.php/HumiditySensor
%value%-3.0Code: Select all
%value%+3.0ESPeasy is well documented here: http://www.esp8266.nu/index.php/HumiditySensor
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Qcvictor
many tanks simonrg, exactly what I looking for
you are right ESP Easy R78
My offset : -3.5 for temperature and + 5 for humidity, did you have something similar?
