If....do problem
Bert84
- Domoticz version: 4.10278
If....do problem
I reckon myself as a starter with Domoticz. I have been looking al over this forum for an answer. I hope anyone can help me.
I have two contact switches. If one of them is "open", I want Domoticz to switch on a light. If they are both closed, the light must be switched of. I have 2 blockies, but they are not working. What am I doing wrong?
jannl
- Domoticz version: 2026.1.x
Re: If....do problem
Do you not need to check for On and Off instead of open and closed?
simonrg
- Domoticz version: 3.8807
This isn't really a Domoticz issue, you would find this easier if you had a play with blockly itself and then made your Domoticz event.
https://developers.google.com/blockly/
Your event as written means:
not what I think you want which is
To get the second you need to add the blocks in the right order not just add left to right as you have done in your code.
So first add if block, then put the or block inside it, then put = blocks on each side of the or block, then fill in the variables and on / open etc..
You should then find your events will work.
Test 1 = (open or (Test 2 = Open))Code: Select all
(Test 1 = open) or (Test 2 = open)So first add if block, then put the or block inside it, then put = blocks on each side of the or block, then fill in the variables and on / open etc..
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Bert84
Thx for the reactions. I checked is and "Open" and "closed" are right.
Mr simonrg: You put me in the right direction. For "Open" I now have the following Blocky, wich is working now:
Thnx for that. Now to figure out how to handle "Closed"
markk
I remember reading somewhere that the "if do" blocks with the "+" don't work if there isn't an "else" command present. For this you need a normal "if do" block.Bert84 wrote:Hello,
mrf68
Hi Bert84,
I think your blockly, as shown in Testopen.JPG, is not built the correct way. Simonrg has explained it well, I want to make it a bit more visual:
First make seperate statements for each thing that needs to be true. In this case you want to check Test 1 and Test 2. So build those 2 statements:
Then combine them in the 'or' statement:
Then take an 'If' block, create a 'Set' statement and there you have it:
And finally you create this:
When you read the text, you will say it sounds exactly what you did in Testopen.JPG, but there is a difference.
simonrg
Great job of visual explanation.mrf68 wrote:I think your blockly, as shown in Testopen.JPG, is not built the correct way. Simonrg has explained it well, I want to make it a bit more visual:
I sometimes wonder whether Blockly (and similar visual approaches) aren't a bit of a confidence trick, in that they appear to be very simple, but really aren't because as soon as you try to do something real it is very complex.
On the other hand Lua appears very complex, but really is a bit complex but not very complex.
I guess this problem is a good case in point.
Obviously, this is only my perception and Blockly does help you avoid spelling things wrong etc., but when you do make a mistake in Blockly it can be less obvious than in Lua. However trying to tell a computer to do something is also prone to errors / misunderstanding, in the same way that giving somebody directions to your house can be.
The equivalent Lua code would be:
-- /home/pi/domoticz/scripts/lua/script_device_tester.lua
if devicechanged["Test 1"] or devicechanged["Test 2"] then
if (otherdevices["Test 1"] == "Open" or (otherdevices["Test 2"] == "Open") then
commandArray["A3"] = "On"
elseif (otherdevices["Test 1"] == "Off" and (otherdevices["Test 2"] == "Off") then
commandArray["A3"] = "Off"
-- Create an empty array to store the commands to be returned to Domoticz at the end of the script
-- Only do the other tests if one of the switches has changed
-- Test whether either of the switches is open
-- If either of the switches is open, then turn A3 on
-- Neither of the switches are on, so test if they are both off
-- If both switches off then turn A3 off
-- Return the commandArray to Domoticz with the command to carry out.
Events - http://www.domoticz.com/wiki/Events
Lua Scripts - http://www.domoticz.com/wiki/Scripts#Lua_Scripts
Bert84
You' ve made it very clear. The blocky' s are working now.
Indeed, it looks simple, but if you make a mistake, its hard to find the mistake.
Maybe its time to take a good look at Lua for me.
Thank you all!
Thank you all!
Evelen
- Domoticz version: 2.4538
me2.Bert84 wrote: Maybe its time to take a good look at Lua for me.
Are there any domoticz specific instructions for lua?
