Can get the fgsd-002 smoke detector into Domotics
Westcott
Re: Can get the fgsd-002 smoke detector into Domotics
Post by Westcott »
It looks like it reports only when its temperature changes by 1 degree.
mvank
Post by mvank »
Yes i though it was the 1 degree, but when i hoover over the line, it tells me on the flatline parts that it received an update every 5 minutes.
Also as you can see, i doesn't report anymore since 13:05
Schermafbeelding 2016-02-15 om 16.29.16.png (72.53 KiB) Viewed 1699 times
stuiow
Domoticz version: 3.6857
Post by stuiow »
Sorry to butt in, got similar setup, but with the FGSD-001.
Do these along with Domoticz actually log smoke levels?
I was hoping for this, but all I see in the log is either 100% or 0% (alarm active or deative in other words).
Hoping to measure smoke levels really (we have a log burning stove, would be handy to monitor smoke in area's of the house)
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
mvank
Post by mvank »
unfortunately still not working as hoped.
reinstalled RPI, with pre-build image.
resetted Aeon USB stick,
resetted smoke detector fgsd-002
still temp sensor not reporting :(
gooxbe
Post by gooxbe »
I have the same,
Z-Stick Gen5 0701 1 DF - cuisine - temp Temp LaCrosse TX3 24.2 C - 100 2016-11-24 19:49:17
33 Z-Stick Gen5 0601 1 DF - SAM - temp Temp LaCrosse TX3 20.2 C - 100 2016-11-24 18:33:57
Not reporting since yesterday when I re installed them...
I put the setting to report every 0,2C°and still...
Anyone have found a fix?
mvank
Post by mvank »
i had to have patience, after several hours it was working fine.
only my battery of smoke detector is almost empty after 9 months,,,, this is not ok...
Also want to increase the number of temp value per month, now i can only see min and max value for older then 24 hours
hoedinie
Post by hoedinie »
I installed 2 sensors and both show big gaps as well in temperature reporting. Anybody already found a fix for this?
