Greenwave Reality (Nuon) switches, overvoltage protection
Sly
Post by Sly »
After having blown up two Greenwave Reality switches (Powernode, Smartplug) bought thru Nuon (The Netherlands) I got curious about the why and how of it.
The first one that blew ruined all Z-Wave communication on the network as long as it was plugged into the mains.
The second one that blew just didn't do anything at all.
It took some digging before things became clear to me.
In the garage there are 6 TL fluorescent tubes which are switched on and off at roughly the same time by means of a double mechanical switch. It seems that switching all the lights off at exactly the same time makes the coils in the (conventional) ballast discharge over the half opened switch, sparking back into the mains. Due to the inductance of the rather long cables back to the house the mains voltage rises quite a bit, causing the Greenwave Reality powernode to die...
The easiest resolution was to insert an APC Surge Arrestor in-between the mains and the new power node..... I can now play the piano on the switches without the powernodes to die on me....
I hope this info is useful for someone....
Sly.
Platform: RPi
RF Interfaces: RFXtrx433 & AEON Labs Z-Stick using Open Z-Wave
Devices: CoCo/KaKu: Switches, dimmers, PIR's and door sensors
Z-Wave: Greenwave Reality / Nuon Powernodes, AEON recessed door sensors, Fibaro FGS-221
coolwine1962
Domoticz version: 2020.1
Re: Greenwave Reality (Nuon) switches, overvoltage protectio
Post by coolwine1962 »
Thx for the info.
I had the same problemen with the Greenwave 6, my whole z-wave network did not function anymore, as long as the defective greenwave powernode was inserted in the main plug.
I suppose you cannot repair them.?
1 x Raspberry Pi4 Raspbian
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
1 X Aeon Z-Wave USB Stick
25 x Fibaro WallPlug
2 x ZRC90
2 x Aeotec MultiSensor
6 x zWave Greenwave 6
4 x zWave Greenwave 1
1 x Pi slave for Electra and Gas
mtalexandru
Post by mtalexandru »
Hello, could you please tell me how where you able to order the Smartplug from Nuon? In the checkout options there is no country selected So I supposed they only deliver in Netherlands. Is there another way of ordering? Or have their policies changed?
Thank you!
djgodlike
Post by djgodlike »
mtalexandru wrote:Hello, could you please tell me how where you able to order the Smartplug from Nuon? In the checkout options there is no country selected So I supposed they only deliver in Netherlands. Is there another way of ordering? Or have their policies changed?
Thank you!
http://www.robbshop.nl/z-wave-stekkerblok-6
Aeon Labs Gen5 USB
Greenwave Powernode 6 NS310
2x Greenwave Powernode 1 NS310
Philips Hue
Logitech media Server
Plugwise Smile P1
