How to get the IDX in bash ?
- warp
How to get the IDX by the name of a device in bash?
Raspberry 2B:RaZberry Z-Wave+:Edimax EW-7811UN:Huawei E220 3G
4xQubino ZMNHCA2
Everspring SE812 & ST812
Mcohome MH-S411 & MH-S412
2xAEON LABS ZW-100
2xFibaro FGSD-002:Fibaro FGFS-101:Fibaro FGS-221 & KLF-050
4xQubino ZMNHCA2
2xAEON LABS ZW-100
paulvha
Re: How to get the IDX in bash ?
the best advice I can give is to use json connection: https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
It is a very strong interface and good documented + a number of examples to start in the wiki
- Egregius
- Domoticz version: v2024.7
Not really by name, but by sequence in a roomplan:
Part of a script I use to shutdown the NAS, except if one of these 2 switches is ON:
jq -r '.result[0].Status' = first switch in roomplan
jq -r '.result[1].Status' = second
#!/usr/bin/bash
DOMOTICZ=`curl -s "http://192.168.0.8:8080/json.htm?type=devices&used=true&plan=6"`
KODI=`echo $DOMOTICZ | jq -r '.result[0].Status'`
if [[ $KODI = "On" ]]; then log "Kodi online, exiting"; exit; fi
log "Kodi Offline"
TOBI=`echo $DOMOTICZ | jq -r '.result[1].Status'`
if [[ $TOBI = "On" ]]; then log "TOBI online, exiting"; exit; fi
log "TOBI Offline"
- jvdz
- Domoticz version: 4.107
This should work based on the devicename. Save in a file like getidx.sh:
Then run: sh getidx.sh "switchname"
Jos
#!/bin/bash
#--Get Domotics Device
IDX=`curl -s 'http://127.0.0.1:8080/json.htm?type=devices&order=name' | /usr/local/bin/jq -r '.result[]|select(.Name == "'$1'")|.idx'`
if [ "$IDX" = "" ]; then
echo "Switchname:$1 not found"
echo "Switchname:$1 has IDX:$IDX"
fi
Jos
deennoo
Wrap post the same in a french forum, dont say hello, thanx or please and this the same here....un minimum de politesse !
http://domo-attitude.fr
Catullus
V. Nov
V
M n.
V
M n.
- warp
Désolé d'avoir oublié de dire bonjour, je pense que cela a du surement t'arriver aussi !deennoo wrote:Wrap post the same in a french forum, dont say hello, thanx or please and this the same here....un minimum de politesse !
Il n'est pas n'nécessaire de me suivre a la trace pour me le faire remarquer !! C'est presque du harcèlement !
4xQubino ZMNHCA2
2xAEON LABS ZW-100
4xQubino ZMNHCA2
2xAEON LABS ZW-100
