The fix didn't work as expected. Too bad.chimit wrote:To keep you updated a bit: Meanwhile I find time for a newer update, I put online just some fixes that prevents the web server part from responding at certain times.
It will be active after the next restart. I will be monitoring, so I can revert back in case of anomalies.
== Rene
MyDomoticz - Testers wanted!
- chimit
- Domoticz version: master
Re: Testers wanted!
erik4281
Re: Testers wanted!
Is there anywhere I can see if the service is online or offline? For the last 2 days I can't get it to work, but I'm expecting it to be a problem of the service. I can't even login anymore...
- chimit
Re: Testers wanted!
The short answer: If you go there and get no page: It's offline.
Even though probably the Domoticz instances will still be connected.
I did just another try. Not being able to plan some proper debugging and testing time introduces the need for quick fixes, unfortunately.
== Rene
== Rene
- deejc
- Domoticz version: 3.5641
Re: Testers wanted!
chimit wrote: This kind of depends on what 2FA app you are using. Some people report that not all authenticators work whilst others do.
In this case, you can always try to enter the secret code manually. Or download a different authenticator.
As far as I can see, the shown barcode uri is according to the official specification. But if somebody sees a mistake, please do tell me about it.
this one works
https://itunes.apple.com/gb/app/otp-aut ... 77384?mt=8
OTP Auth
By Roland Moers
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
- chimit
Re: Testers wanted!
Dear Raspberry beta testers,
Does the following crash occur with more people than just me? It happens upon clean program termination when using the mydomoticz service.
I assume that I am not the only one. But strange thing that no one reported this before.
- chimit
Re: Testers wanted!
JC38 wrote:Today, with the latest avalaible beta for Rpi, I've made a test to enable again remote Domoticz sharing using the ID.
Things are a little bit better (or the log is more verbose) but still don't work.
On the remote Rpi (the slave) :On the master Rpi2016-01-19 23:01:47.416 PROXY: Master disconnected
2016-01-19 23:02:07.200 PROXY: Authenticate result: success.
2016-01-19 23:02:07.262 Incoming Domoticz connection via Proxy accepted for user Myusername.
2016-01-19 23:02:47.599 PROXY: Master disconnectedBut with these errors :2016-01-19 22:58:43.294 PROXY: Notification received: slave instanceID online now.
2016-01-19 22:59:03.336 PROXY: Authenticate result: success.
2016-01-19 23:01:04.701 Domoticz TCP connected via Proxy.
2016-01-19 23:02:02.505 PROXY: Authenticate result: success.
2016-01-19 23:02:07.203 PROXY: Notification received: slave instanceID online now.
2016-01-19 23:02:07.297 Domoticz TCP connected via Proxy.
2016-01-19 23:03:02.738 PROXY: Authenticate result: success.So, no remote devices appears on the master.2016-01-19 23:01:32.396 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:01:32.397 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:01:32.431 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:01:39.739 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-01-19 23:02:32.510 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:02:32.578 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:02:32.615 Error: PROXY: Shared Server access disallowed, denying receive data request.
2016-01-19 23:02:43.929 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
Just testing with this. It seems the shared domoticz access needs to be enabled on the master as well.
I will assign this case as an issue to myself on Github as well.
- deejc
Re: Testers wanted!
i am only seeing these every few minutes..
2016-02-05 21:01:24.997 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-02-05 21:03:30.246 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-02-05 21:03:40.321 Error: PROXY: Connect failed, reconnecting: Network is unreachable
2016-02-05 21:05:40.501 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
bullrin
- Domoticz version: 2.4403
Re: Testers wanted!
I tried to test MyDomoticz service. I have a DS Lite connection (only ipv6) But it's not working. My Instance is shown as red.
Domoticz shows the instance id under settings.
On the Status tab in the log there is this entry: PROXY: Authenticate result: IP not whitelisted.
And there error log is full with this: 2016-02-05 20:00:53.975 Error: PROXY: Connect failed, reconnecting: Operation canceled
One question, is there any configuration needed for the ip whitelist field?
- chimit
Re: Testers wanted!
Could you check again?deejc wrote:i am only seeing these every few minutes..
- chimit
Re: Testers wanted!
You can leave the ip whitelist empty for now. But it should work, also for ipv6 addresses. I will PM you.bullrin wrote:I tried to test MyDomoticz service. I have a DS Lite connection (only ipv6) But it's not working. My Instance is shown as red.
bullrin
Re: Testers wanted!
I can't answer your pm. There is no answer button. Are there any restrictions in this forum? Could you please send me your email adresse or something via pm?chimit wrote: You can leave the ip whitelist empty for now. But it should work, also for ipv6 addresses. I will PM you.
- deejc
Re: Testers wanted!
all looks good now, thankschimit wrote: Could you check again?
MattLittle
Re: Testers wanted!
Hi guys.
First time post. First of all thanks Chimit for an awesome product, I hope you are reaping some rewards for your hard work.
I am trying to get mydomoticz up and running. I have managed to log in and get the little green man + my dashboard a couple of times, however only after a reboot of my linux box, which is an HP Mini running ubuntu. My dom version is 2.4347. After a short amount of time however the wee man turns red, and I get errors like
"Error: PROXY: Handshake failed, reconnecting: short read
2016-02-09 00:06:00.121 Error: PROXY: Connect failed, reconnecting: Network is unreachable
2016-02-09 00:08:08.958 Error: PROXY: Handshake failed, reconnecting: short read
2016-02-09 00:08:09.015 Error: PROXY: Handshake failed, reconnecting: short read
2016-02-09 00:08:09.431 Error: PROXY: Connect failed, reconnecting: Network is unreachable
2016-02-09 00:08:20.166 Error: PROXY: Connect failed, reconnecting: Network is unreachable
2016-02-09 00:10:22.216 Error: PROXY: Handshake failed, reconnecting: short read
2016-02-09 00:10:22.273 Error: PROXY: Handshake failed, reconnecting: short read
2016-02-09 00:10:22.695 Error: PROXY: Connect failed, reconnecting: Network is unreachable"
in the log.
At the moment the webpage is unavailable so I assume you are still fiddling around with the server side of things Chimit?
My question is should I be running a different version of dom (alpha relase?) or should 2.4347 have all the goodies?
Should there be any fiddling around with my router/firewall settings??
I am aware its in alpha stage so will be a bit flaky which is fine, just wanted to make sure Im lining my ducks up at this end.
Thanks for your time.
Matt
in the log.
Matt
- chimit
Re: Testers wanted!
Yeah, there is an issue at the moment.
Maybe a firewall thingy. Will need to check.
- chimit
Re: Testers wanted!
The issue has been identified. It was after a code update, but I forgot to re-compile before restarting the proxy.
Apologies for the inconvenience. You might want to restart your domoticz in order to reconnect to mydomoticz.
== Rene
== Rene
MattLittle
Re: Testers wanted!
Awesome. Working well at present, if not a bit slow in my phone (guessing its a small pipe at present?). Just flicked you 20 euros via paypal.
bullrin
Re: Testers wanted!
Is the service currently offline?
- chimit
Re: Testers wanted!
Nopes. Just checked: Online for 4h32m5s.
- Minglarn
- Domoticz version: v3.8153
Re: Testers wanted!
It my domoticz down?
Trying to ping the address with 100% package loss..
PING my.domoticz.com (188.166.24.182): 56 data bytes
--- my.domoticz.com ping statistics ---
5 packets transmitted, 0 packets received, 100% packet loss“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
- chimit
Re: Testers wanted!
The host is up. Just it doesn't return echo replies.
