how accurate are the power consumption meter ?
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Are the energy meter capable of measuring the very small consumtion ? Like the consumption of mobile charger connected on the power but not in use (around 0,x Wh)
Are the instantaneous measure true ?
Are this consumption taken into consideration into the incremental count ?
Could you advise me a model ?
thank you,
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
paulvha
Re: how accurate are the power consumption meter ?
Post by paulvha »
it shows in KW and watt, not a behind the decimal comma as the meter does not provide that.
I have it running to update every minute and it shows up a split second later.
It shows the usage compared to the previous KWH sample + the actual usage.
I don know what you mean with the request for advice on the model
regards,
Paul
gizmocuz
Post by gizmocuz »
If you use a zwave device to measure the power, then you have decimals
Egregius
Domoticz version: v2024.7
Post by Egregius »
Yes, but how accurate is it?
I had it once activated on some Qubino relays. After some time the reports showed that a powersaving E27 bulb of 9 watt consumed more Kwh than 4 58W TL bulbs wich are more used.
I don't really get the idea of all those power measurements (except maybe to see if a fridge or freezer isn't consuming to much).
If you allready use powersaving bulbs, led bulbs etc. You also allready use Domoticz so most of the lights will be switched of automatically when not needed.
So what can you save with all the info? Are you gonna wach less TV if you see that it's 20% of your total consumption?
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
You have to view 'accuracy' from 2 angles:
1) what you see at the display or in de data-interface
2) the measuring accuracy of the device
At the display or in the data-interface the number of digits 'behind the comma' is just a choice by the manufacturer and has no direct relation with the measuring accuracy: on the other hand it makes no sense to show more digits than supported by the measuring accuracy.
The measuring accuracy in the specification is a testcriterium. If you have a kWh-meter with MID-qualification, than it is suitable 'for making bills', and strangely jumping readings and 'unbelievable values' should not occur.
Look in the specification of your device in which category it operates.
householder
Domoticz version: last
Post by householder »
jmleglise wrote: Tuesday 02 February 2016 23:35 Could you advise me a model ?
P3 P4400 a good one
