Getting started with GEN 5 ZWave - help please?
Information about specific Z-Wave devices
900zenith
Post by 900zenith »
I am going to use my Windows PC to access some Z Wave devices from Aeon. I also bought a Gen 5 ZWave Stick from Aeon. and loaded all the Domoticz software.
My dumb question: what next? I installed the driver and all was OK, but what do I have to do in Domoticz to make the stick "seen", or is that it now? I think when I get going I will be OK, but for now it seems like a huge black hole....
Thanks in advance for any little pointers.
George ...
StanHD
Re: Getting started with GEN 5 ZWave - help please?
Post by StanHD »
Hi, have you added the Open Z-wave Hardware? (Settings > Hardware > Pull Down List)
Python:- Broadlink RM2, Sonos
900zenith
Post by 900zenith »
Thanks. I had tried that but it didn't see the COM port that the Driver assigned to it. I changed the USB socket and then restarted the Browser. One of these did the trick and it is now added. So thanks for the suggestion.
Now that I see the screen I know something else new. I only thought I was lost before, now I am certain...
That said I think there is going to be some fun to be had. (if it doesn't beat me down first).
Thanks again.
Emmanuel
Post by Emmanuel »
Now you need to discover Zwave compatible devices (sensors, switches, etc.).
From the Setup /Hardware menu, select the setup button on the Zwave stick. In this screen, you can "Include node" (i.e. discover Zwave compatible devices you have installed)
Once a new node is added, the Setup / Devices screen will display the discovered device (sensor, switch...). You can give it a name (Rename button) and "Use" it (green arrow button) : it will create a switch or sensor in the Switch / Temp screens.
Emmanuel
