DCH-Z110 Door/Window Tamper issue
drhans
Post by drhans »
I just got 6 DCH-Z110 door/window sensors and Aeon Z-Stick Gen 5 and decided to go with Domoticz after testing other controllers. I can add all nodes just fine and the door/window sensor reports correctly open/close state. Luminance, temperature and battery work great too. But I'm stuck on the tamper sensor, I can't get it to work but this is pretty essential function so I don't want to give up.
Whenever I release the tamper button, I see that Alarm Type and Alarm Level values log "Off" value. So something happens, but something else than I would expect. The problem is that this Off comes also automatically after some time (like 8 hours) despite no tampering happening and the Off is also logged whenever the window closes or opens. So this is not the right tamper detection.
Could someone please suggest what am I doing wrong? Attaching 2 images if that might help. The log shows "OpenZWave: Alarm Level: Secure" when I release the tamper button but also whenever window opens/closes.
Here's the log:
2016-02-02 13:07:56.608 New sensors allowed for 5 minutes...
2016-02-02 13:07:56.612 OpenZWave: Node Include command initiated...
2016-02-02 13:07:58.177 OpenZWave: New Node added. HomeID: 4177569116, NodeID: 4 (0x04)
2016-02-02 13:07:58.183 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-02-02 13:07:58.183 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2016-02-02 13:07:58.185 (zstick) Lighting 2 (Unknown)
2016-02-02 13:07:58.215 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2016-02-02 13:07:58.216 (zstick) Lighting 2 (Unknown)
2016-02-02 13:07:58.248 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-02-02 13:07:58.250 (zstick) Lighting 2 (Unknown)
2016-02-02 13:08:10.454 OpenZWave: Received timeout notification from HomeID: 4177569116, NodeID: 4 (0x04)
2016-02-02 13:08:10.675 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-02-02 13:08:10.676 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2016-02-02 13:08:10.724 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2016-02-02 13:08:10.724 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Access Control, Instance: 1
2016-02-02 13:08:10.725 (zstick) Lighting 2 (Unknown)
2016-02-02 13:08:11.734 (zstick) Lux (Unknown)
2016-02-02 13:08:11.780 (zstick) Lux (Unknown)
2016-02-02 13:08:11.824 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:08:11.836 OpenZWave: Alarm Level: Secure
2016-02-02 13:08:11.837 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:08:11.849 (zstick) Lighting 2 (Access Control)
2016-02-02 13:08:12.093 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:08:12.106 OpenZWave: Alarm Level: Secure
2016-02-02 13:08:12.107 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:08:12.120 (zstick) Lighting 2 (Access Control)
2016-02-02 13:10:11.900 (zstick) Temp (Unknown)
2016-02-02 13:12:11.238 (zstick) Temp (Unknown)
2016-02-02 13:14:10.503 (zstick) Temp (Unknown)
2016-02-02 13:16:10.071 (zstick) Temp (Unknown)
2016-02-02 13:22:09.339 (zstick) Temp (Unknown)
2016-02-02 13:22:52.128 (zstick) Lighting 2 (Sensor)
2016-02-02 13:23:09.333 (zstick) Temp (Unknown)
2016-02-02 13:24:09.463 (zstick) Temp (Unknown)
2016-02-02 13:25:09.788 (zstick) Temp (Unknown)
2016-02-02 13:25:35.976 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:25:35.990 OpenZWave: Alarm Level: Secure
2016-02-02 13:25:35.990 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:25:51.172 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:25:51.196 OpenZWave: Alarm Level: Secure
2016-02-02 13:25:51.196 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:26:10.182 (zstick) Temp (Unknown)
2016-02-02 13:26:47.085 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:26:47.098 OpenZWave: Alarm Level: Secure
2016-02-02 13:26:47.099 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:27:10.744 (zstick) Temp (Unknown)
2016-02-02 13:29:00.912 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-02-02 13:29:00.912 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2016-02-02 13:29:00.914 (zstick) Lighting 2 (Unknown)
2016-02-02 13:29:00.945 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2016-02-02 13:29:00.946 (zstick) Lighting 2 (Unknown)
2016-02-02 13:29:00.972 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-02-02 13:29:00.973 (zstick) Lighting 2 (Unknown)
2016-02-02 13:29:01.254 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:01.277 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:01.277 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:29:01.291 (zstick) Lighting 2 (Access Control)
2016-02-02 13:29:01.315 (zstick) Lux (Unknown)
2016-02-02 13:29:01.327 (zstick) Temp (Unknown)
2016-02-02 13:29:03.217 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:03.230 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:03.231 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:29:03.245 (zstick) Lighting 2 (Access Control)
2016-02-02 13:29:03.260 (zstick) Lux (Unknown)
2016-02-02 13:29:03.266 (zstick) Temp (Unknown)
2016-02-02 13:29:04.319 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:04.333 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:04.333 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:29:04.347 (zstick) Lighting 2 (Access Control)
2016-02-02 13:29:04.361 (zstick) Lux (Unknown)
2016-02-02 13:29:04.367 (zstick) Temp (Unknown)
2016-02-02 13:29:11.047 OpenZWave: Received timeout notification from HomeID: 4177569116, NodeID: 2 (0x02)
2016-02-02 13:29:11.086 (zstick) Lighting 2 (Sensor)
2016-02-02 13:29:11.140 (zstick) Lux (Unknown)
2016-02-02 13:29:11.185 (zstick) Lux (Unknown)
2016-02-02 13:29:11.215 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:11.229 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:11.230 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:29:11.244 (zstick) Lighting 2 (Access Control)
2016-02-02 13:29:11.259 (zstick) Lux (Unknown)
2016-02-02 13:29:11.265 (zstick) Temp (Unknown)
2016-02-02 13:29:11.278 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:11.292 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:11.293 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:29:11.306 (zstick) Lighting 2 (Access Control)
2016-02-02 13:29:11.715 (zstick) Temp (Unknown)
2016-02-02 13:29:16.786 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:16.811 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:16.812 (zstick) Lighting 2 (Alarm Level)
2016-02-02 13:29:16.826 (zstick) Lighting 2 (Access Control)
2016-02-02 13:29:16.839 (zstick) Lux (Unknown)
2016-02-02 13:29:16.846 (zstick) Temp (Unknown)
2016-02-02 13:29:21.132 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-02-02 13:29:21.133 (zstick) Temp (Unknown)
2016-02-02 13:29:29.257 (zstick) Lighting 2 (Alarm Type)
2016-02-02 13:29:29.271 OpenZWave: Alarm Level: Secure
2016-02-02 13:29:29.271 (zstick) Lighting 2 (Alarm Level)
Thank you
msantic
Domoticz version: 2024.4
Re: DCH-Z110 Door/Window Tamper issue
Post by msantic »
Hello!
Also planing to buy Aeon Z-Stick Gen 5 and D-Link DCH-Z110 door/window sensors for my Domoticz installation.
I would be very grateful if you could tell me whether you are satisfied with D-Link DCH-Z110 door/window sensors ?
Here in Croatia I can buy it for about 30 EUR and it is cheapest Z-Wave door sensor.
Thank you.
Mladen
