I added a Monoprice Dual Zwave relay, that has since been removed, but ever since I did that I now see a lot of devices that do not exisit and sending a command to them results in a unable to contact error. Is there anyway to clean up devices in Domoticz database?
Cleanup Database Topic is solved
- gizmocuz
Re: Cleanup Database
Yes, from the same view, select them and press delete ?
Jtoler5
I only get that option if I'm under Hardware and OpenZwave setup. This is under the Devices page.gizmocuz wrote:Yes, from the same view, select them and press delete ?
Jtoler5
Didn't notice the small trash icon. Never mind. Thanks
