Cheap wireless temp/humidity sensors in Scandinavia
Biltema sells a couple of different weather stations with wireless 433 MHz temperature & humidity sensors.
You can buy extra sensors individually for 89.90 DKK, and they work flawlessly with RFLink and Domoticz.
Personally, I've tested the 84-0871 model, and it got picked up immediately by the RFLink as a "Prologue", subtype "WTGR800".
There's a switch behind the battery door, allowing you to switch between 3 different "channels", so I assume that's the most you can have in the same area.
- Domoticz version: V2.3530
Re: Cheap wireless temp/humidity sensors in Scandinavia
Thanks for the tip, ill check it out, im trying now with a sensor from Clas Ohlson, but it aint coming up in device list.
http://www.clasohlson.com/no/Temperatur ... er/36-1797
- Domoticz version: 3.x
Good to know, thanks! I've tested 84-056 with no luck (rfxcom/rflink).
- jumbotroll
This sensor is not working here with RFXCOM, but it's working with RFLink.Larsja wrote:Thanks for the tip, ill check it out, im trying now with a sensor from Clas Ohlson, but it aint coming up in device list.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
This is now working with RFLink, think its in update 1.39oopee wrote:Good to know, thanks! I've tested 84-056 with no luck (rfxcom/rflink).
- Domoticz version: 3.4866
I use a couple of these with my RFXtrx433E. You need to enable the Hideki/UPM protocol which is only supported by the Type 1 firmware. Their range is pretty bad though.jumbotroll wrote:This sensor is not working here with RFXCOM, but it's working with RFLink.Larsja wrote:Thanks for the tip, ill check it out, im trying now with a sensor from Clas Ohlson, but it aint coming up in device list.
- Domoticz version: V3.8650
Can confirm this. I have three of these in use.thestewed wrote:I use a couple of these with my RFXtrx433E. You need to enable the Hideki/UPM protocol which is only supported by the Type 1 firmware. Their range is pretty bad though.jumbotroll wrote:This sensor is not working here with RFXCOM, but it's working with RFLink.Larsja wrote:Thanks for the tip, ill check it out, im trying now with a sensor from Clas Ohlson, but it aint coming up in device list.
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
I've got three of them. Two were working, but one device wasn't. The latest RFLink update has fixed it.
- Domoticz version: 4.10717
Biltema 84-0871 humidity/temperature sensor
How many of these Biltema 84-0871 sensors you can use simultaneously with Domoticz?
I know that these sensors support 3 channels but what does that mean? In this picture I can see different ID for every sensor. So can you add eg 5 of these sensors to your Domiticz?
I found similar sensor
Renkforce Ersatz-/Zusatzsensor KL4931 Thermo-hgyro sensor 433 MHz wireless
https://www.conrad.com/ce/en/product/13 ... z-wireless
Price is 28,99 €.
Same sensors Art. 84-0871 in Biltema costs 10,90 €.
Clas Ohlson is selling teperature/humidity sensor Co/Tech 36-6726. 9,90 €
Price is 28,99 €.
