Cheap Chinese WIFI module
leby
- Domoticz version: 2020.2
Hi All,
I just found what seams to be a cheap WIFI switch on dx.com, anyone managed to control this or similar from Domoticz? And I dont have any 433 only z-wave devices to day so it would be via the WIFI that would make the trick..
http://www.dx.com/p/diy-smart-wi-fi-wir ... oUi3xXhDWI
or
http://www.dx.com/p/diy-wi-fi-wireless- ... oUiWRXhDWI
Perhaps one should not use for heavy load but for smaller, lights?
or
/lennart
andriej
Re: Cheap Chinese WIFI module
If it uses http protocol, then you could use simple scripts (ran by switch) to control it.
Orange Pi (@ Debian) / MySensors Serial / GPIO / Custom Serial 433 MHz Transmitter (for plug switches and livolo wall switches) / JSON&Bash API scripts
- Keptenkurk
- Target OS: -
Lennart,
Both units use a ESP8266 (i like the Sonoff better) so have a look at ESP8266 posts to see how to interact with it from Domoticz.
You could even run micropython on it. BTW also available at Banggood
/paul
/paul
SweetPants
But that requires connection to the serial port to re-program the module.Keptenkurk wrote: You could even run micropython on it. BTW also available at Banggood
- Keptenkurk
- Target OS: -
If you search through the micropython link it says : This box, has a switch, light, and a relay on board. The the serial port is run to the edge ready for headers. The switch is is on GPIO0 so all you have to do is solder some headers and hold the button down to reflash it. It runs my micropython perfectly.
Haven't seen one myself but well worth to give it a go. I'll order one to find out!
/paul
/paul
leby
Thx, but to complicated for my skill level... Well, just an idea, will stay with z-wave for now...
/lennart
- Keptenkurk
- Target OS: -
Thanks for the pointers anyway!
/paul
/paul
Raspberry Piet
Very nice module this sonoff!
I soldered the pin-headers at j1 and flashed espeasy on it.
It has 512kB 1MB flash size.
I'm thinking of cramming an ACS712 for current measuring in to this module. Have to investigate available pins.
Last edited by Raspberry Piet on Monday 25 January 2016 22:12, edited 1 time in total.
Karelin
- Domoticz version: 2.4223
Do any of you know if the RfxTrx433 supports the "Sonoff-protocol"?
And yes, the Sonoff looks pretty interesting..and cheap..
Raspberry Piet
Don't know about the 433Mhz Sonoff-protocol.Karelin wrote:Do any of you know if the RfxTrx433 supports the "Sonoff-protocol"?
My Sonoff module is a wifi-only version.
jossie67
Piet,Raspberry Piet wrote:Very nice module this sonoff!
Do you have de model with wifi and 433?
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
Raspberry Piet
Nope, wifi only version here.jossie67 wrote:Piet,Raspberry Piet wrote:Very nice module this sonoff!
Flashed OTA MiniESPEasy on it. Now it will be easy to connect i2c devices.
SweetPants
Just flashed one with my own MQTT image after modifying for this hardware.
Works great, and cheap too
deennoo
Just a question about this (i ordre 6pcs) but 1 question remain.
About output, this a 230v output with L+N ? Like can be a kaku wall switch ?
http://domo-attitude.fr
SweetPants
Yes, L/N in, 2 wire load out.deennoo wrote:Just a question about this (i ordre 6pcs) but 1 question remain.
deennoo
Great thx
- bbqkees
- Domoticz version: 4.1x
I succesfully reflashed a Sonoff module to ESPEasy R78 with an Arduino Uno.
This might also be useful for others when you do not have a usb-serial cable at hand.
During the entire procedure below, do not connect the mains voltage!
First solder the 4-pin header. Then connect 3.3V and GND of the Arduino to the header.
Pin near switch: 3.3V
Rx
Tx
GND
(for pinout also see internet).
Then connect the 2 remaining wires to Tx and Rx of the Arduino (Arduino pin 1 and 0).
Furthermore you need to connect the reset pin of the Arduino to ground.
Plug in the Arduino to the pc and (download and) open the EspEasy flash tool (flash.cmd).
Choose the COM port of the Arduino, set the size to 1024 and choose a revision (78).
Now before you press enter press the button on the Sonoff and keep it pressed until the flash tool is ready (might not be necessary to keep it pressed al the time).
If the flash tool gives an error switch the wires on Tx and Rx and try again.
If it still does not work, unplug the 3.3V wire on the Sonoff, and while pressing the button on Sonoff reconnect the 3.3V wire.
Then flash it again.
If it worked you get the ESP0 network.
Rx
Tx
GND
alexsh1
- Domoticz version: v3.8975
I have Sonoff RF and this is not an easy process to flash this one as one has to touch the R21 pads with a screwdriver (pulls GPIO0 to GND to enter the flash mode) on the PCB before giving a 3.3 V power via FTDI
NOTE: DO NOT PLUG 240V while uploading the firmware!
I still have to figure out the RF part - I found this https://www.itead.cc/blog/itead-intelli ... or-arduino
I manage to pair but still cannot switch on/off which is very annoying.
Derik
- Domoticz version: BETA
Dear..andriej wrote:If it uses http protocol, then you could use simple scripts (ran by switch) to control it.
Do you have an example of the script?
Edit:
Is this possible without a Espeasy flash?
So i mean is there a WiFi Sonoff Api?
superczar
Just tried out one with ESP_easy firmware - Was a fairly easy process if you are a little famiilar with soldering
Works far better than my flaky (and expensive) Wemos -and small enough to be housed inside the wall electrical panels
Ordering a bunch of these doohickeys
