How to combine separate codes for a blind into one blind swi
cherowley
Post by cherowley »
Hi!
My rf projector screen remote sends the following codes:
Up: Type=EV1527 ID=0000D4AD Unit=2
Stop: Type=EV1527 ID=0000D4AD Unit=8
Down: Type=EV1527 ID=0000D4AD Unit=4
So as a result when learning the remote in domoticz i end up with 3 separate switches.
How can i combine them into one blind switch (was thinking of the venetian eu blind switch)?
Can you set domoticz to transmit different codes for each action on the same switch?
Cheers!
nigels0
Domoticz version: 3.8153
Re: How to combine separate codes for a blind into one blind
Post by nigels0 »
Its a good point. If you use a blind with up/stop/down then you can put the up and down commands in the on action and off action fields - but there is nothing there for stop. Suggest you either augment with a lua script or request a new feature in a future version.
Check out http://www.domoticz.com/forum/viewtopic.php?f=38&t=3360
