Integration of Fibaro Dimmer 2 in Din Rail housing
Quax1507
Post by Quax1507 »
I integrated a Fibaro Dimmer 2 into an empty DIN Rail housing (german Hutschiene) for mounting in electrical Distributor box.
I removed the cover from Dimmer 2 and had to cut the plastics (green) of the connector a few millimeters to fit inside.
You can buy empty housings at http://www.conrad.com
Quaxx
JacquesMulders
Re: Integration of Fibaro Dimmer 2 in Din Rail housing
Post by JacquesMulders »
Witch housing did you use, there are so many... do you have a order nr?
proohu01
Post by proohu01 »
JacquesMulders wrote:Witch housing did you use, there are so many... do you have a order nr?
I think this is what you are looking for....
https://www.conrad.nl/nl/axxatronic-din ... 32664.html
Pi 2 B | Pi Camera | PiFace 2 | RFXtrx433E (KaKu + Oregon Scientific) | Plugwise (9 Circles) | Aeon Z-Wave stick (Fibaro - dimmers, sockets, RGB, screens/blinds) | RFXMeter (Kwh/water/gaz) | WOL | Onkyo Receiver | RTC | Hikvision | Netatmo | Satel Integra
Quax1507
Post by Quax1507 »
