pepeEL
Re: Domoticz app 2.0
Post by pepeEL »
I update to version 0.1.222 and problem with setpoint thermostat is still. When i setup temp up and ex. Set 24 then on screen after click OK is show 24.5 but when i setup down ex 22.0 on sceen show 21.5
Still is problem when i first click on "-" set up but second click set down. Only first click is not correct.
Maybe good option will be add feature to select path where export setting and also select from where for import...
Wysłane z mojego SM-G920F przy użyciu Tapatalka
pluggin
Post by pluggin »
First of all GREAT APP!!!
I am using the Lite version and found the following issue.. I have same protected sensors and when I put the PIN on the panel always tell me "incorrect pin" but all works fine via Domoticz front end web.
Is this a mal function or something else?
BTW what is the difference between Lite vs Pro version.
Kind regards
Razberry + 4 Eversrping HSM02 + 2 Aeotec Multi-Sensor + 1 Aeotec Micro Dimmer + 4 Aeotec Micro Smart Energy Switch, 2nd + 1 Remotec ZXT-120 + 1 Aeotec Smart Energy Monitor + 1 Everspring SE812 indoor Siren + 2 fibaro motion sensor + Aeotec water sensor
pepeEL
Post by pepeEL »
Issue #71 describe on github is still and also issue #48
maluko
Post by maluko »
I think that the last beta version hás a bug on widget, i add the widget on home, but after a while it goes down, widget cant refresh.
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
pepeEL wrote:I update to version 0.1.222 and problem with setpoint thermostat is still. When i setup temp up and ex. Set 24 then on screen after click OK is show 24.5 but when i setup down ex 22.0 on sceen show 21.5
Yes, known issue. Still working on it.
Will think about the select path feature request.
RoadXY
Post by RoadXY »
RickDB wrote:Thanks for adding EvoHome supports!
Only a few small issues with it so far:
- Can set global temperature mode however the green "SET" icon is misaligned in potrait mode as it overlaps the text label (name) and adds a an empty white space below (like it expects more info in a new row)
- Missing per zone temperature control, can see the temps of every EvoHome thermostate (zone) however no option to control it yet.
Sorry about that, here you go :) :
For the temperature zones it displays the data like before with no option to set temperature (believe EvoHome control is slightly different) however the mode control there ("Honeywell - huis modus") works perfectly fine now except for the label alignment.
Thanks. Got it. Will put it on the list.
pepeEL
Post by pepeEL »
I think that button SET should be change size to small size. Now is too big
RoadXY
Post by RoadXY »
maluko wrote: this is quite equal that i said about group button.
group dont seem to be the solution, because domoticz has 2 button (on and Off), and on app it has a slide button so you cant push off or on twice.
yes, like i said:
i have a scene with :
blind A- close
Blind B- open
Blind C- Close
Blinde D- Open
if they are all close only open B/D but if all open, the A/C goes closed, then if i want close/open all when are mixed?
i had a group with all blind that in domoticz i can click on or off when they are mixed, that not happen on app because if the status of group on app are off and the blind are mixed how can i close? have to open group and then close? or close every blind individual?
other think is:
my blind system not have stop button, so if blinds are close and want to all stay at middle i have to click ON (group) to open,wait 10s and that click On again to stop at middle. this happen with close too, OFF to close and OFF again to stop.
thanks
Ah, yes. Mixed status of the devices. Got it.
Will add it to our list!
RoadXY
Post by RoadXY »
pluggin wrote:First of all GREAT APP!!!
Kind regards
Currently support for protected devices is on alpha test and deployed to a limited group of users.
Did you meant security panel perhaps?
Regarding the difference between the versions.
The Premium has all the features of the free with addition of:
  • Android Wear support
  • Widgets
  • Geofencing
  • Support and acknowledgement for the developers :roll: :D
bvduijv
Post by bvduijv »
pepeEL wrote:I think that button SET should be change size to small size. Now is too big
I agree. Not so nice atm. I like the size of the day, month and year buttons from temp sensors [CHART WITH UPWARDS TREND] .
RoadXY
Post by RoadXY »
I tend to agree with you on this.
Will throw this in the group for debate.
RoadXY
Post by RoadXY »
pepeEL wrote:Issue #71 describe on github is still and also issue #48
Is still, what?
RoadXY
Post by RoadXY »
We do use words and all words of all languages should fit.
But where still looking into this.
pepeEL
Post by pepeEL »
Is still, what?
Still is problem with issue describe on GitHub in #71 and #48 in version 0.1.222
pluggin
Post by pluggin »
Kind regards
  • Widgets
  • Geofencing
Thanks for your reply.
Yes I'm talking about the security panel. This is the functiuonality I'm looking for :D
RoadXY
Post by RoadXY »
pluggin wrote:Thanks for your reply.
So pincode of the security panel is always wrong?
RoadXY
Post by RoadXY »
pepeEL wrote:
Is still, what?
Are you looking at the old or the new github issue list?
New issue list:
https://github.com/domoticz/domoticz-android/issues
pepeEL
Post by pepeEL »
Yes i look on this issue.
pluggin
Post by pluggin »
correct :(
RoadXY
Post by RoadXY »
correct :(
Hmm, ok. I'll investigate further.
