How to send more than one sensor info via JSON
Jumper3126
Post by Jumper3126 »
I have been succesfull in getting my particle core to send the data of a single temperature sensor to a dummy device in domoticz using the code below:
            if (client1.connect(server, 8080)){
                    client1.print("GET /json.htm?type=command&param=udevice&idx=50&nvalue=0&svalue=");
                    client1.print(String(temp));
                    client1.println(" HTTP/1.0");
                    client1.println("Host: home.dtdns.net");
                    client1.println("Content-Length: 0");
                    client1.println();
                    ledStatus(2, 300);
                    delay(1000);
                    client1.flush();
                    client1.stop();
                else {}
Now I would like to send the data of other sensors as well to different Domoticz devices.
What would be the best way to do this? I was able to copy past the whole code, including the
, but perhaps I just only need to repeat
GET /json............... HTTP/1.0
Regards, Rutger
bbqkees
Domoticz version: 4.1x
Re: How to send more than one sensor info via JSON
Post by bbqkees »
When sending data to Domoticz via 'JSON URL's' you are actually performing a HTTP GET request to your Domoticz server.
You have to complete the whole HTTP GET request per sensor value before starting a new one.
I do it like the following with my Arduino's;
Every sensortype has it's own request function like this:
// /json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEMP
void httpRequesttemp() {
  // if there's a successful connection:
  if (client.connect(server, port)) {
    Serial.println("client connected sending temp value");
    //Serial.println(dstemp);
    client.print( "GET /json.htm?type=command&param=udevice&idx=");
    client.print(IDXtemp);
    client.print("&nvalue=0&svalue=");
    client.print(dstemp);
    client.println( " HTTP/1.1");
    client.println( "Host: 192.168.x.xxx");
    client.println( "Connection: close");
    client.println();
    client.println();
    client.stop();
    //delay(requestdelay);
  else {
    Serial.println("client could not connect (DS value)");
    client.stop();
You need to put that AFTER the 'void loop' part.
(So outside of the 'void loop' brackets)
Then inside the loop you add a check to see if the specific sensor interval has passed.
If so (and the value seems OK), send the specific request.
Other sensors can have different intervals. For most temperature sensors I use an interval of 1 minute.
Repeat the entire part below in the 'void loop' for every sensor.
If the interval is the same you can just add the request function for the specific sensor in the same if>interval function.
 // loop for DS18B20 sensor
  if(millis() - lastTimetemp > intervaltemp) {
    lastTimetemp = millis();
    //DS readout starter
    sensors.requestTemperatures();
    dstemp = sensors.getTempC(thermometer);
    // Only send data to Domoticz if the data is valid
    // If the data read fails, the reported temp will be -127C.
    // A bit cold to register that in Domoticz!
    // So everything below -40C will be ignored.
    if(dstemp >=-40){
    httpRequesttemp();
    else {
    Serial.println("dstemp not valid! No HTTP request made.");
As soon as you are using multiple sensor types or doing other stuff on the Arduino it is important to avoid using delay().
Delay() will 'pause' the processor and in the mean time it does nothing, this will give timing issues in the long run.
If you are using DHT sensors you might skip the Adafruit library and use another one because the Adafruit library is very slow and big.
And if you use a DHT or other humidity sensor you need to calculate wet/dry/normal etc too.
Depending which ethernet controller you are using you might need some tweaking with timing and maybe an additional client.println(); here and there.
bbqkees
Post by bbqkees »
Also,
If you have more than 1 sensor of the same sensor type rewrite the function to accept parameters below.
Now you can reuse the same function for all sensors.
f.i.:
// define sensor 1
float sensor1 = 0;
int sensor1IDX = 210;
// define sensor 2
float sensor2 = 0;
int sensor2IDX = 212;
httprequesttemp(sensor1, sensor1IDX);
httprequesttemp(sensor2, sensor2IDX);
void httpRequesttemp(float value, int id) {
    //Serial.println(value);
    client.print(id);
    client.print(value);
    client.println();
    client.println();
    client.stop();
  else {
    client.stop();
Jumper3126
Hi bbqkees,
Thanks for your explanation. I'm using the particle core, which is nice small and cheap controller with wifi. Although the reception can sometimes be a bit tricky.
I have placed the whole communication part outside the loop:
void DomoticzTempUpdate(String DomData, String IDX){
    Serial.println();
    Serial.println("Updating to Domoticz... ");
    Serial.println("Date string: " + DomData + "to device: " + IDX);
    if (client.connect(server, 8080)){     // Connecting and sending data to Domoticz
        Serial.println("Domoticz connection succesful");
        client.print("GET /json.htm?type=command&param=udevice&idx=");
        client.print(IDX);
        client.print(DomData);
        client.println(" HTTP/1.0");
        client.println("Host: home.dtdns.net");
        client.println("Content-Length: 0");
        client.println();
        ledStatus(3, 250);
        Serial.println("Thingspeak update sent.");
        delay(200);
    else{ // Failed to connect to Thingspeak
        Serial.println("Unable to connect to Domoticz.");
        ledStatus(4, 100);
    if(!client.connected()) {client.stop();}
    client.flush();
    client.stop();
Which I call on for each temp sensor with:
            DomoticzFloat=((round(TempInside*10))/10); // round float to 1 decimal
            DomoticzTempUpdate(String (DomoticzFloat), "4"); // change float to string and send
bbqkees
Post by bbqkees »
Jumper3126 wrote:Hi bbqkees,
Ok I was under the assumption you were using an Arduino like me.
But good to hear it works.
