Problem with LightWave PIR
cjnicholl
Domoticz version: 2564
Post by cjnicholl »
I have a domoticz system with a RFXTRX433e transmitter receiver.
I have purchased a Lightwave PIR which I can add to the system using "Learn Light Switch" but it then doesn't react at all.
Should it be set up in Domoticz as a motion sensor or a basic switch and what should the setting switches on the back of the PIR be set to?
b_weijenberg
Re: Problem with LightWave PIR
Post by b_weijenberg »
Is the sensor detected in RFXmngr with only the LightwaveRF protocol enabled?
RFX-433, RFX-433EMC, RFX-868
cjnicholl
Post by cjnicholl »
I only have the lightwave protocol enabled in the settings
b_weijenberg
If you have enabled Accept new Hardware Devices or better pushed the Allow for 5v minutes button you should receive the motion sensor as a LWRF On/Off device.
Please check with RFXmngr on a Windows system if nothing received in Domoticz!
cjnicholl
Post by cjnicholl »
When I learn the switch it gives me the option to choose what the device is. Should I choose switch rather than motion sensor?
Thanks for your help
nigels0
Domoticz version: 3.8153
Post by nigels0 »
I've found these to be VERY range limited. Firstly replace the batteries and then move it close to your transceiver to see if that helps. It should be set up as a motion sensor but will always appear on.
I use Simonrg's excellent smartPIR lua scripts to manage them (when they work!) check out https://www.domoticz.com/wiki/Smart_Lua_Scripts - that should solve the usability problem.
cjnicholl
Post by cjnicholl »
It was a range problem. The PIR is quite close to the RFXCOM unit but it's a new extension packed with foil backed insulation.
