Trying to run LUA Script got error 'popen' not supported-osx
karde
- Domoticz version: 3.7412
I'm trying to run a battery check script (http://www.domoticz.com/wiki/Battery_level_check).
I have installed JQ with brew, but when Domoticz try to run the script I get the following error in domoticz log:
"Error: EventSystem: /Users/johan/domoticz/scripts/lua/script_time_battery.lua:37: 'popen' not supported"
Don't know what popen is, but as I understand this has something to do with Lua?
I have also tried to install LUA (and have curl installed as well), is there someway you can check that you have popen installed? Is there any path you have to change in domoticz? :/
In a terminal window in osx I can successfully type:
MacMiniVpn:~ johan$ lua
Lua 5.2.4 Copyright (C) 1994-2015 Lua.org, PUC-Rio
> popen
Thanks for any help!!
> popen
karde
Re: Trying to run LUA Script got error 'popen' not supported
So the error is on line 37, right? :/ tried to change a bunch os stuff but is there any better way you can test the script and see what the error might be?
Is there any better way to see battery level than the script? Get notifications and so forth..
This is what I have on line 37
local handle = io.popen("/usr/local/bin/jq -r '.\"" .. DeviceName .. "\" | values' " .. DeviceFileName)
Have the server on a MacMini osx with JQ | LUA and Curl installed.
Johan
Johan
simonrg
- Domoticz version: 3.8807
The error suggests that popen is not implemented in the version of Lua inside the Mac OSX version of Domoticz. The version you have installed is not the version executed by Domoticz. In test of Lua you haven't actually completed a popen command, so that version may not have popen.karde wrote:This is what I have on line 37
Even if you didn't have the popen issue, the script is set up to run on a Raspberry Pi, everything will be different on Mac OSX.
/usr/local/bin/jq is the path to jq on Linux, so on your Mac OSX where is jq executable - could be something like /Users/yourname/jq/jq. You will also need to make sure that the user Domoticz runs under is allowed to execute jq.
Try in your external version of Lua something like io.popen("jq") and see if that give an error other than popen not implemented, if so then try to correct the battery script with the correct paths for Mac OSX for jq you might not need a path, Mac OSX may just find it, try in Domoticz and see if you get a different error message.
Good luck, Simon
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
karde
Hmm, ok :/, but the path for jq seems to be /usr/local/bin for me, but, I see that the filename in the script is called "JsonAllDevData", and jq -r says:
-r output raw strings, not JSON texts;
Isn't the user which you installed domoticz the user that's trying to execute.., it should be johan.
lrwxr-xr-x 1 johan admin 24 Jan 12 22:40 jq -> ../Cellar/jq/HEAD/bin/jq
I have version 1.5 of jq though.
MacMiniVpn:bin johan$ pwd
/usr/local/bin
MacMiniVpn:bin johan$ jq -r
jq - commandline JSON processor [version ]
Usage:
jq [options] <jq filter> [file...]
jq is a tool for processing JSON inputs, applying the given filter to
its JSON text inputs and producing the filter's results as JSON on
standard output.
The simplest filter is ., which copies jq's input to its output
unmodified (except for formatting, but note that IEEE754 is used
for number representation internally, with all that that implies).
For more advanced filters see the jq(1) manpage ("man jq")
and/or https://stedolan.github.io/jq
Example:
$ echo '{"foo": 0}' | jq .
"foo": 0
Some of the options include:
-c compact instead of pretty-printed output;
-n use `null` as the single input value;
-e set the exit status code based on the output;
-s read (slurp) all inputs into an array; apply filter to it;
-R read raw strings, not JSON texts;
-C colorize JSON;
-M monochrome (don't colorize JSON);
-S sort keys of objects on output;
--tab use tabs for indentation;
--arg a v set variable $a to value <v>;
--argjson a v set variable $a to JSON value <v>;
--slurpfile a f set variable $a to an array of JSON texts read from <f>;
See the manpage for more options."
Sorry, but what do you mean by:
"Try in your external version of Lua something like io.popen("jq")"
Thank you for your help!!
/usr/local/bin
Usage:
standard output.
Example:
"foo": 0
-C colorize JSON;
simonrg
Start Lua by typing Lua, then enter:karde wrote:Try in your external version of Lua something like io.popen("jq")
io.popen("/usr/local/bin/jq")However, it would appear that if jq was in the same place as Linux, then no reason why popen shouldn't have worked in the script, so it would appear that for whatever reason the popen is not implemented in the Mac OSX Domoticz Lua.
karde
Getting this:
MacMiniVpn:bin johan$ lua
no return... but no failure.
Should it work then? Do you think this mean that no LUA script will work on OS X distribution of Domoticz :/, that's a bummer then..
Getting this:
simonrg
Ok, so we now know that there is a version of Lua on Mac OSX in which popen is implemented.karde wrote:Should it work then? Do you think this mean that no LUA script will work on OS X distribution of Domoticz :/, that's a bummer then..
Lua is working in Domoticz for you, as you are getting the error about popen, so it is just a matter of getting a different version of Lua included within Domoticz.
Have you installed Domoticz from a binary or compiled it?
Best bet now is to find somebody who is building Domoticz on Mac OSX and seek their advice.
karde
:/ Ok, thanks for your help!
compiled from the below source, with this guide "https://www.domoticz.com/wiki/Mac_OS_X"
git clone https://github.com/domoticz/domoticz.git domoticz
DrMacabre
- Domoticz version: 4.11590
Re: Trying to run LUA Script got error 'popen' not supported-osx
I'm running into a similar issue with a different script.
Just to make sure, i tried lua command with no success but i had lua52 installed.
any idea why its not working from within domoticz ?
root@domoticz:/ # lua
lua: Command not found.
root@domoticz:/ # lua52
> /usr/local/bin/jq: not found
- Siewert308SW
- Domoticz version: Stable
As it aint a Domoticz issue but Raspberry issue.DrMacabre wrote:Hello,
any idea why its not working from within domoticz ?Code: Select all
root@domoticz:/ # lua lua: Command not found. root@domoticz:/ # lua52 Lua 5.2.4 Copyright (C) 1994-2015 Lua.org, PUC-Rio > io.popen("/usr/local/bin/jq") > /usr/local/bin/jq: not found
If im correct then i did the following when i ran into the same problem.
sudo apt-get update
sudo apt-get install build-essential
sudo apt-get install jq
And changed "/usr/local/bin/jq" to "/usr/bin/jq"
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
trixwood
On mac if you have homebrew installed:
brew install jq-
DrMacabre
Sorry, i forgot to mention i'm on freenas trying to run the Lux Sensor script which has nothing to do with JQ.
Still, i have this popen not supported error and no one seems to have a clue why. :/
trixwood
if popen is not supported try using
os.execute
and save the output to a file in the tmp file, read that...
os.execute
DrMacabre
Good, at least it's going to the next linetrixwood wrote:if popen is not supported try using
os.execute
- 2016-12-27 11:10:00.600 Error: EventSystem: in Lux Sensor: [string "--[[ Virtual Lux sensor and other real-t..."]:66: attempt to index local 'config' (a boolean value)
- local config=assert(io.popen('curl http://api.wunderground.com/api/'..wuAP ... ty..'.json'))
local location = config:read('*all')
config:close()
trixwood
What i mean was as workaround:
http://lua-users.org/wiki/OsLibraryTutorial
non tested code:
non tested code:
-- tmpfile = /tmp/whatever.tmp
-- or let lua generate one
tmpfile = os.tmpname()
-- pipes to file 'curl http://api.wunderground.com/api/....json/ > /tmp/whatever.tmp'
command = 'curl http://api.wunderground.com/api/'..wuAPIkey..'/conditions/q/'..countryCode..'/'..city..'.json') .. ' > ' .. tmpfile
-- 'popen' has output direct, but with 'execute' its in the file...
os.execute(command)
local config = io.open(tmpfile, "r")
local location = config:read("*all")
config:close()
DrMacabre
Thank you very much, I'll give it a try.
DrMacabre
hi, missing a ( before 'curl http://
local location = config:read('*all') instead of ("*all") may be ?
still getting an error.
2016-12-29 05:05:00.018 Error: EventSystem: in Lux Sensor 2: [string "--[[ Virtual Lux sensor and other real-t..."]:76: attempt to index local 'config' (a nil value)
trixwood
well looking at the code:
there is a typo i think... there should be no )
but it was pseudo code...but i have no running domoticz at the moment to test anything...
command = 'curl http://api.wunderground.com/api/'..wuAPIkey..'/conditions/q/'..countryCode..'/'..city..'.json' .. ' > ' .. tmpfile
DrMacabre
ok. i removed the ) error is still here (a nil value)
thats weird, i've read the whole topic about this script, seems to be working pretty fine for everyone with a lot of debugging since the origin of the code.
thanks for your help.
DrMacabre
I've tested the api, it returns all the proper data btw.
