This is my first post on this forum but I am reading forum for the last month
I want to thank you all for the fantastic work you are doing
I hope you will be able to help me with my problem
I have a fibaro HC2 already installed to control my home, I have also somfy RTS shuters which I want to control too, but fibaro has only zwave.
after some time spent reading docs and forums I think optimal solution is to have domoticzPI+RFXCom which will be controlled by fibaro
I was able to send status from domoticz to fibaro by fibarolink but I can't send commands from fibaro to domoticz.
Please help
how to control domoticz from fibaro
partiris
Re: how to control domoticz from fibaro
One year ago I modified my Telis4 remote control by adding a Fibaro 2x1,5KW module. One switch for opening and the other for closing the shutters.
This solution was used because the RfxComm did not yet support the Somfy protocol at that time.
The advantage of this solution is that the original Somfy Telis4 RC is still working and can be used to manually open and close the shutters while using a standard Fibaro module to "push the buttons".
But ..... it will only work to open or close all shutters at once (Telis4 mode 5). This way it's not possible to control every single shutter by Fibaro.
You can find more info on my site: http://onsheim.nl/prive/domotica/z-wave-somfy-besturing (Sorry.... until now only in Dutch).
pepeEL
Can you tell me and show foto how you conect 2x1.5kw fibaro to remote somfy?
SOMFY is working on 433MHz ? I have RFLink and i see that RFLink support somfy. But i have remote somfy telis 4 and i dont know what is frequency.
But wheni connect 2x1.5 relay and click to close pin by relay are still connect until i click to off relay. Right?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
partiris
Sorry for the uncorrect link. We are changing and moving our website. I just enabled the new unfinished site to give you the possibility to read the complete article on http://onsheim.nl/domotica/onze-oplossi ... -besturing
But to address your question, you can parameterize the Fibaro module to give a pulse , so automaticly opening the contacts again after you closed them. This is done by setting parameters 3 and 4 to 3 seconds.
pepeEL
It is a pity that the web is not in the English language and picture is very small. But anyway thank you for your help.
pepeEL
This is parametr 3 and 4 and 5. I must enable 3 parametra and then set time in 4 and 5 parametrpartiris wrote: But to address your question, you can parameterize the Fibaro module to give a pulse , so automaticly opening the contacts again after you closed them. This is done by setting parameters 3 and 4 to 3 seconds.
